Is it acceptable to use to fronts instead on a center?
Nightsbane
Nightsbane Posts: 100
I ask because it looks like I will have to send in my cs1 for repairs. I have monitor 50 fronts. Would it be acceptable/recommended to go down to no center for the several weeks it will take it get repaired? I listen to movies loud, and I don't want at all to risk messing up the more expensive speakers that ARE working.
Your thoughts please would be great!
Post edited by Nightsbane on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2010
    I watch a lot of tv in my HT system, some channels don't have use the front speaker but use the L/R speakers only. :( Pisses me off some, but I guess your question is ok. ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Nightsbane
    edited March 2010
    That's what I am trying to find out, is if it will be ok on the speakers. I play stuff pretty loud sometimes and don't want to damage those side speakers since they weren't I am guessing built for center channel use.
    If I do this, I also need to know how to make my receiver not use the center channel? I have a Sony dg820
  • disneyjoe7
    edited March 2010
    I sure if you setup the HT so the center speaker is not connected (since it's on the store, and not in your house) it will use the L/R speaker vs the center speaker when it's use. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • fbm211
    fbm211 Posts: 1,488
    edited March 2010
    Some people prefer a phanton center channel.I know I do, and yes your speakers will be ok.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • mantis
    mantis Posts: 17,538
    edited March 2010
    fbm211 wrote: »
    I just gotta know why do you prefer a phantom center to a real center channel? What are your benefits to and negatives with having one?
    Dan
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2010
    You will be fine, those 50's can handle it by themselves.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Nightsbane
    edited March 2010
    If someone could find out if the sony dg820 has a phantom center and how to turn it on that would be great. I am scrambling to find out myself as I type this heh.
  • wutadumsn23
    edited March 2010
    I would just run the auto calibration program (Digital Cinema Auto Calibration) and it should be able to detect that there is no center hooked and will compensate for it. If not, look into the menu and see if you can disable it manually. There is no "Pantom center" option that I know of.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • Nightsbane
    edited March 2010
    It looks like in the manual you can select 2/4.1 speaker configuration to select no center. This is all speakers but the center.
    I guess that's what I need. I have no idea if that affects digital sound or how it will work, but it looks like I will have to give it a shot.
  • wutadumsn23
    edited March 2010
    That is another option as well, but if you have the mic. I would strongly suggest you run the auto calibration program and let it do it's thing. It will setup many more things than just doing it manually and will probably get you better results. Just my $.02.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
