RTA 11T Upgrade Kit
koukaiwen
koukaiwen Posts: 7
edited March 2010 in DIY, Mods & Tweaks
Any opinions on this upgrade kit? I have a set of rta 11t's and was wondering if this worth it?
http://cgi.ebay.com/Polk-Audio-Monitor-10-RTA-11T-Upgrade-Kit_W0QQitemZ260562091073QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3caab5fc41
Post edited by koukaiwen on
  • Dominion
    Dominion Posts: 69
    edited March 2010
  • fbm211
    fbm211 Posts: 1,488
    edited March 2010
    You would be better off getting those parts yourself from parts express.
    Those caps with the yellow ends are a mid grade dayton brand.You should at least get the higher grade 1% daytons.
    Or better yet get sonicaps from soniccraft but keep in mind they cost more.Not sure what values you need but someone else here who has modded those 11s may chime in and let you know what you need and where to get it.
    Welcome to club polk.
    You can upgrade them to the TL version too I think
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • zarrdoss
    zarrdoss Posts: 2,562
    edited March 2010
    you will need
    high
    new polyswitch or .5ohm resistor
    12uF capacitor x2
    2 ohm resistor
    2.7 ohm resistor
    low
    34uF capacitor
    per speaker
  • fbm211
    fbm211 Posts: 1,488
    edited March 2010
    Try the mundorf resistors for a little high end sheen.Or mills for a warmer sound.
  • mhmacw
    mhmacw Posts: 832
    edited March 2010
    if you power with a receiver and plan to stay there those will siffice. if you have the slightest thought of seperate(or integrated) amplification id go with the other suggestions
  • Conradicles
    Conradicles Posts: 6,390
    edited March 2010
    fbm211 wrote: »
    Have you fbm211 personally heard both and have hands on knowledge to make this kind of statement?:confused:
