I want to build a tube phono Pre
ben62670
I am looking to build a phono pre on a very limited budget. I am thinking http://glass-ware.stores.yahoo.net/aiphpcb.html . Any other ideas in a similar price range would be appreciated.
Ben
Ben
Ben
Ben
Post edited by ben62670 on
I should be getting a custom built tube pre this week to borrow for a few days.
I haven't seen it yet but everybody that has said it's the ****.
Gary from intrinsic sound built it and wants $1200 for it.
I say do it if anybody here can you can. -
These things are paint by number. You can easily do it too. If I were you I would look into building one yourself. The down fall for me is the cases. I know you can build them no problem so you are ahead of the game.
Ben -
I can build you a case just tell me what size, If I make it out of aluminum it would be nothing for you to put the holes where you want them.
On a side note I need glasses, I just saw you said phono pre, I was talking about a pre/amp:) -
No experience with the boards at the link posted; they look rather complex (generally not such a good thing IMNSHO). They certainly look nice, though.
The basic RCA circuit sounds very good but can be a bear to get quiet. It is based on the 7025/12AX7 -- not the most exciting high-gain dual-triode, but certainly a venerable candidate for vacuum tube MM phono preamps.
You can see it in, e.g., http://www.pmillett.com/tubedata/RC20.pdf (note: this is a 22 MB D/L!) see page 412 of the manual (which is pg. 414 of the PDF file).
The Bottlehead Seduction is a nice sounding phono preamp kit (point to point rather than on a PCB) but 1) gain is a bit limited and 2) it isn't so inexpensive anymore. This is the one I use (so, yes, I am a bit biased). -
I couldnt resist bro.
link>>http://cgi.ebay.com/Fisher-Tube-Phono-Preamp-PR66-RARE-LOOK_W0QQitemZ250585628999QQcmdZViewItemQQptZVintage_Electronics_R2?hash=item3a58114147SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Hi Ben,
check out hagerman coronet II. I think a complete setup is about $400 but the schematic is online I believe.
http://www.hagtech.com/cornet2.html
I thought I had saved other lower priced phono pre amp stuff but I cant find it now. I will look some more. Are you going to use a MM cart?Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
I think I will build this one.
http://glass-ware.stores.yahoo.net/tetra.html
http://tubecad.com/Product_PDFs/Tetra_Phono.pdfPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Looks good Ben but its out of stock. Are you going to make it your self point to point?Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
I will wait for the kit. Not ready for point to point yet.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Wonder how good this would be for $70. The power supply is about $180.
http://classixaudio.com/7Cpp1.htm
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Thanks for the link. I think I may just go wit the tetra because it has the PS included.
Ben -
I think with the Tetra you still have to supply some of the components and the transformer.>
With the tetra all I need is the transformer, and I have that.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Hi Ben,
The Hagerman is very nice. Check out mine that Scompracer built:
http://www.polkaudio.com/forums/showthread.php?t=88166Carl -
I want that . . . give it to me now!!!:D:p -
I figured out what to build point to point
http://phonoclone.com/diy-pho3.html
Very simple and uses the 6DJ8 tubes.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
