What Sub do you think I should use ?
disneyjoe7
disneyjoe7 Posts: 11,435
edited October 2003 in Speakers
Looking for a sub. Like Velodyne, But open to ? Like sub's that are small like a box, Not tall and round.
System
Onyko 898
Fronts RTi800
Center CSi400
Rear RTi600
Room is 18'x 12' vaulted ceilings top is 13'.
Steve K.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    edited October 2002
    M&K! I like their subs, they have the ac. for music and the punch for ht! and most of their subs go below 20....but for a small sub? infinity? velodyne? etc...they'll work
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • liv4fam
    liv4fam Posts: 311
    edited October 2002
    Rel acoustics, Velodyne SPL or HGS series, Sunfire True Sub or JR. (hard to set-up for music), Paradigm, Def Tech Super Cube , etc etc.
    Do some Demoing and Have fun only your ears can tell you.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited October 2002
    What's your budget Joe? Ballpark it, $300, $600, 1 large? More?
    Cheers,
    Russ
  • disneyjoe7
    edited October 2002
    Thinking about HGS-12" or CHT-15", But afraid of something too large to tune to rest of my setup.
    Buget is under $1500 or so.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • liv4fam
    liv4fam Posts: 311
    edited October 2002
    Wow if your Budget is 1500 you can get into some really great subs in that price range. You should definitely go listen to the Rels because they are very musical and sound absolutely amazing right out the box. B&W also makes incredible subs at that price range.
  • Frank Z
    Frank Z Posts: 5,860
    edited October 2002
    Sunfire Audio True Sub!!
  • disneyjoe7
    edited October 2002
    Thanks all, You're all QUICK.
    One more thing, Like music. Bass that I can feel in the chest. Also feel I'm missing something when it comes to explosions. Movies like the opening to ToyStory2 and Lethal Weapon4 Gas truck fire ball, The Matrix building explosion.
    Sorry to re-ask, But any change.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • TroyD
    TroyD Posts: 13,124
    edited October 2002
    I would also give serious thought to the Paradigm Servo-15. The best sub that I've demoed and can be had new for under 1500.
    BDT
  • jdavy
    jdavy Posts: 380
    edited October 2002
    I like a ballanced sound field and would stick to a Polk sub to match the Polk front and center speakers. The PSW 350 is a perfect match for the 800i and 400i.
  • organ
    organ Posts: 4,969
    edited October 2002
    What's your price range? If you're looking for a small sub, the best looking one I've seen(small sub) is the sunfire. Very tiny with 2 woofs and a super plate amp. If you're looking for subs around 1-2k, consider the Paradigm Servo15 or the PW2200. The paradigms are big but they sound very nice.
    You don't need a Polk sub to achieve a "balanced soundfield", but if you really want to go Polk try checking out the new models. Looks much better than the PSW350(specs and looks).
    Maurice
  • MxStYlEpOlKmAn
    edited October 2002
    MILLLLLLLLLER AND KREISEL! THEY HAVE A KICK ARSE SUB FOR 1500!!!!!!!!!!!!!!!!!!!
    I promised myself
    Damn you all! - ATC
  • RuSsMaN
    edited October 2002
    The Sunfire designs are passive radiator, if I'm not mistaken. 1 active woof, 1 pr....
    Cheers,
    Rooster
  • mantis
    mantis Posts: 17,377
    edited October 2002
    wth the budget gotta go ReL..........Strata 3......sealed, clean,musical,powerfull, dual preamps........10 inch,hits down to 20hz,can be setup for both music and movies seperately,I can't see any reason not to at least give a listen.
    I forgot to mention offered in cherry.......walnut........black ash........just another reason to go REL
    Dan
  • disneyjoe7
    edited October 2003
    Thanks to all,
    Well after moving / buying a new house, room size change and all.
    I have decided on the Paradigm Servo-15, must say very impressed.
    Steve K.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited October 2003
    Edit: Missed this entire thread while bow hunting. Didn't realize it was after the fact and you had already got the Servo-15. Enjoy it, it's a good sub.
    Doc
    Original Post Below:
    Are you kidding me?
    SVS PB2-Plus for $1,200
    Twin 12" ultra high output dB12 Plus drivers.
    900 watt digital BASH amp.
    Three huge dual flared 4" vents.
    Multiple tuning points with custom SS filter and EQ settings for each point.
    Continuously variable 0-180 phase control.
    115 pounds of rock solid muscle and finesse - built like a brick **** house.
    This sub will stomp into dust anything in its price range. It will play flatter, cleaner, louder, and lower. Period. Better for movies, better for music - just plain 'ol better.
    Even in the stock tune, the PB2+ is strong (rising response with room gain) to 21 Hz in-room before the SS filter kicks in. And it can dig even deeper to 15 Hz in the 2/20 tune with still power and SPL to spare.
    Don't look elsewhere - SVS is the final word in subs in this price range.
    SVS
  • bigsexy1
    bigsexy1 Posts: 557
    edited October 2003
    Doc, look at the dates on the threads. I doubt SVS was even making boxes then. Certianly they weren't as well known as now.
    Edit- well, your edit just barely beat my post.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2003
    May not be too late... Note that dj7 said "have decided", not "have purchased"...
    More later,
    Tour...
    Vox Copuli
  • Inferior_Light
    Inferior_Light Posts: 14
    edited October 2003
    If you want something that will knock you off your feet buy an SVS Subwoofer they can't be beat, ask anyone @ AVSforus.com
  • disneyjoe7
    edited October 2003
    Ok, let me clear this up a little.
    I did purchase the Servo-15 and I'm very happy with it.
    I even like the "Blue Light" showing P
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
