A5 and PSW 505 setting question
dfranks
I have normally set my (mains)A5's to small and 505 XO to 80hz.
I am starting to find there is an empty spot (when listening to music on 2 channel) in the sound where the A5's stop and the sub begins.
To improve on this should I set my A5's to large and leave th XO at 80Hz?.
Or should I XO the sub higher than 80Hz and keep the A5 set to small?
Or leave it all as is and start moving the sub around the room?
I know my room layout is probably not helping the separation 16'X20' with many doors in it as it is the 3rd level in a 4 level split.
My current setup is.
yamaha rxv 861 (soon to be replaced by a panny)
Acurus 2X150
RTI A5 (mains)
TC265 (center)
RC85I, and RC55I (surrounds)
thanks in advance
Acurus 2X150
RTI A5 (mains)
TC265 (center)
thanks in advance
Post edited by dfranks on
I would try it at 100hz then 120hz and find which sounds best to you. Remember your room can effect the sound so you need to dial the speakers and sub to your ears.engtaz
Thanks for the response. I am pretty sure I will have to adjust and play with it for a while...
I'd try raising the crossover point some. I've always preferred a 120hz XO point on my subs.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Where exactly is the "empty spot"? What frequency?Pioneer 1018
Polk RTIA5's
CSIA6
RC80I's
SVS PB12-nsd -
comfortablycurt wrote: »I'd try raising the crossover point some. I've always preferred a 120hz XO point on my subs.
Higher frequencies become more localized. I ran mine at 80 and the sub at 80 for HT , but for music I ran them at full range/large. -
When I XO the sub at 80HZ and run the A5's small. In HT the sound is pretty good with that setup. -
I have gone from "large" to 100hz and everywhere in between with my 8's (your predecessor). Right now I am at 40 and like it. However, I am listening to a lot more 2 channel now than HT. Good luck.7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
