A5 and PSW 505 setting question
dfranks
dfranks Posts: 207
I have normally set my (mains)A5's to small and 505 XO to 80hz.
I am starting to find there is an empty spot (when listening to music on 2 channel) in the sound where the A5's stop and the sub begins.
To improve on this should I set my A5's to large and leave th XO at 80Hz?.
Or should I XO the sub higher than 80Hz and keep the A5 set to small?
Or leave it all as is and start moving the sub around the room?
I know my room layout is probably not helping the separation 16'X20' with many doors in it as it is the 3rd level in a 4 level split.
My current setup is.
yamaha rxv 861 (soon to be replaced by a panny)
Acurus 2X150
RTI A5 (mains)
TC265 (center)
RC85I, and RC55I (surrounds)
thanks in advance
Post edited by dfranks on
  • engtaz
    engtaz Posts: 7,669
    edited February 2010
    I would try it at 100hz then 120hz and find which sounds best to you. Remember your room can effect the sound so you need to dial the speakers and sub to your ears.
    engtaz
  • dfranks
    dfranks Posts: 207
    Thanks for the response. I am pretty sure I will have to adjust and play with it for a while...
  • comfortablycurt
    comfortablycurt Posts: 6,745
    I'd try raising the crossover point some. I've always preferred a 120hz XO point on my subs.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Todd Lee
    Todd Lee Posts: 73
    Where exactly is the "empty spot"? What frequency?
    Pioneer 1018
    Polk RTIA5's
    CSIA6
    RC80I's
    SVS PB12-nsd
  • leroyjr1
    leroyjr1 Posts: 8,785
    Higher frequencies become more localized. I ran mine at 80 and the sub at 80 for HT , but for music I ran them at full range/large.
  • dfranks
    dfranks Posts: 207
    edited March 2010
    Todd Lee wrote: »
    When I XO the sub at 80HZ and run the A5's small. In HT the sound is pretty good with that setup.
  • squeeb
    squeeb Posts: 426
    edited March 2010
    I have gone from "large" to 100hz and everywhere in between with my 8's (your predecessor). Right now I am at 40 and like it. However, I am listening to a lot more 2 channel now than HT. Good luck.
    7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
    Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
    Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
