Vintage Polk Drivers
falconcry72
falconcry72 Posts: 3,580
edited February 2010 in Vintage Speakers
What's the difference between all the 6500 series drivers? Is assuming that higher numbers are newer and thus better an accurate assessment?
What drivers are in Monitor 10B's?
I ask beacuse I noticed that my rta12c's have 6501's and my monitor 5's have 6502's.
THANK YOU!:)
Post edited by falconcry72 on
  • ben62670
    ben62670 Posts: 15,969
    The 6511's and 6503's are 4ohms nominal. The rest are 8ohms
    Edit: I think 6509s are 4 ohms also.
    Ben
    Ben
  • mmadden28
    mmadden28 Posts: 4,283
    THANK YOU!:)
    The attachment in this thread has a listing of the drivers in many of the vintage non-SDA polks.
    https://www.polkaudio.com/forums/showpost.php?p=861387&postcount=18
    ____________________
    Pool: Atrium 60's/45's
  • falconcry72
    mmadden28 wrote: »
    Thanks man! I looked through those schematics breifly but didn't see that replacement parts list, otherwise I wouldn't have posted! When I go to that post through the link in yor post and then click the attachment it won't open, but if if go to through the parent thread to it it does open:confused:
    are any better than others???
    F1nut Posts: 51,998
    Different driver specs for purposes, nothing to do with older, newer or better, worse.
  • falconcry72
    fair enough. well what about mixing drivers, not in the same speaker, but, say, in the same home theatre setup. I know that matching the tweeters is more important, but can mis-matched drivers sound bad? For example: rta12c's (6501's), monitor 5's (6502's), and monitor 10's (6503's). Is that combo less than ideal because of the different drivers? BTW they all have sl2000's (soon to be rd0's if I can save the loot). THANks!!:)
  • Schurkey
    Schurkey Posts: 2,122
    Polk sometimes mixed drivers in the same speaker cabinet.
    heiney9 Posts: 25,497
    The later SDA's had better drivers, in that the voice coils were wound differently. It makes sense that an MW6510 or MW6511 is slightly more up to date than say an MW6500X or MW6501. Baskets and materials are obviously the same.
    BUT, that doesn;t mean you can innerchange all the drivers with different models, beyond just matching the ohms. All the MW drivers have that similar Polk sound but I would use whatever driver was originally used. You could call Polk an they could tell you what the next best model to use is, if you can't find an original.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    ben62670 wrote: »
    Ben
    10 ohms I was told from Polk CS. (for the 6509).
    F1nut Posts: 51,998
    That would work perfectly.
  • Schurkey
    Sounds about right. I measured dc resistance on the eight 6509s I have; lowest was 8 ohm, highest was 9.5.
    Kinda disappointed in the wide range; I had expected them to be tighter tolerance.
