Vintage Polk Drivers
falconcry72
What's the difference between all the 6500 series drivers? Is assuming that higher numbers are newer and thus better an accurate assessment?
What drivers are in Monitor 10B's?
I ask beacuse I noticed that my rta12c's have 6501's and my monitor 5's have 6502's.
THANK YOU!:)
THANK YOU!:)
Post edited by falconcry72 on
The 6511's and 6503's are 4ohms nominal. The rest are 8ohms
Edit: I think 6509s are 4 ohms also.
Ben -
falconcry72 wrote: »...
THANK YOU!:)
The attachment in this thread has a listing of the drivers in many of the vintage non-SDA polks.
https://www.polkaudio.com/forums/showpost.php?p=861387&postcount=18____________________
Pool: Atrium 60's/45's -
Thanks man! I looked through those schematics breifly but didn't see that replacement parts list, otherwise I wouldn't have posted! When I go to that post through the link in yor post and then click the attachment it won't open, but if if go to through the parent thread to it it does open
are any better than others???2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Different driver specs for purposes, nothing to do with older, newer or better, worse.Political Correctness'.........defined
President of Club Polk -
fair enough. well what about mixing drivers, not in the same speaker, but, say, in the same home theatre setup. I know that matching the tweeters is more important, but can mis-matched drivers sound bad? For example: rta12c's (6501's), monitor 5's (6502's), and monitor 10's (6503's). Is that combo less than ideal because of the different drivers? BTW they all have sl2000's (soon to be rd0's if I can save the loot). THANks!!:)2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Polk sometimes mixed drivers in the same speaker cabinet.falconcry72 wrote: »can mis-matched drivers sound bad? For example: rta12c's (6501's), monitor 5's (6502's), and monitor 10's (6503's). Is that combo less than ideal because of the different drivers? -
The later SDA's had better drivers, in that the voice coils were wound differently. It makes sense that an MW6510 or MW6511 is slightly more up to date than say an MW6500X or MW6501. Baskets and materials are obviously the same.
BUT, that doesn;t mean you can innerchange all the drivers with different models, beyond just matching the ohms. All the MW drivers have that similar Polk sound but I would use whatever driver was originally used. You could call Polk an they could tell you what the next best model to use is, if you can't find an original.
Ben
10 ohms I was told from Polk CS. (for the 6509). -
falconcry72 wrote: »fair enough. well what about mixing drivers, not in the same speaker, but, say, in the same home theatre setup. I know that matching the tweeters is more important, but can mis-matched drivers sound bad? For example: rta12c's (6501's), monitor 5's (6502's), and monitor 10's (6503's). Is that combo less than ideal because of the different drivers? BTW they all have sl2000's (soon to be rd0's if I can save the loot). THANks!!:)
That would work perfectly.Political Correctness'.........defined
Sounds about right. I measured dc resistance on the eight 6509s I have; lowest was 8 ohm, highest was 9.5.JohnLocke88 wrote: »10 ohms I was told from Polk CS. (for the 6509).
Kinda disappointed in the wide range; I had expected them to be tighter tolerance.
