downward angle fxis?
Airplay355
Airplay355 Posts: 4,298
edited October 2003 in Speakers
i have the fxi30s on the back wall of my room, the couch is going to be right up against that wall. would it be a good idea to angle them downward or is this unheard of? did anyone try this and find it was to their liking? i dont really feel like taking my speakers off the wall and messing around with it right now so i figured id ask for some opinions first. would that destroy the effect created by the fx speakers?
pictures of my room can be found in this thread, http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=13184&highlight=proud+enough+to+share
Post edited by Airplay355 on
  • dorokusai
    dorokusai Posts: 25,628
    edited October 2003
    Duffman has actually done that, if I am recalling his pictures accurately. Omnimount 20 was the mount, they are available from Crutchfield.
  • Airplay355
    edited October 2003
    i have a better idea, just unscrew the screw from the wall alittle. whats it sound like tho?
  • acdds
    acdds Posts: 253
    edited October 2003
    I alway thought the idea of the Fxi30's or any dipole/bipole speaker was to create a diffuse sound that was very difficult to localize. So pointing the speaker down at the listening position may defeat that purpose. I have mine on speaker stands at ear level to the left and right of my sofa. This is mainly because I didn't want to mount the on the wall and I tried them at about 2ft above the listening position and thought the sound was too diffuse. Try it and if you like it, then I say go for it!
    Receiver = Denon AVR-3803
    DVD = Denon DV-2900
    Fronts = SDA SRS 2.3TL's
    (Carver m1.5t)
    Center = CSi40
    Side surrounds = Fxi30's
    Sony 12" sub
    TV = Hitachi 57F500
    Bedroom rig:
    Pioneer SX-1050 receiver
    Rti38's
  • faster100
    faster100 Posts: 6,124
    edited October 2003
    Polk and others reccomend pointing speakers staright forward, their is no need to angle or point rears at least.. it needs to fill the room, not you.. specifically.....
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • brettw22
    brettw22 Posts: 7,623
    edited October 2003
    I concur that angling fx's is pointless. The only reason that I'd see for using something like Omnimounts, is if you dont' have enough space on the wall section to mount the speaker to. I don't think that there would be a sound difference per se because you're not altering the direction of the sound (substantially), just the way that the speaker is hanging.....
  • eclypse
    eclypse Posts: 595
    edited October 2003
    I've heard its a good idea to point them down a tad.. But yeah you want them firing over the head so it dont distract from the fronts and center.. Though the reason to point them down a tad is to make sure you dont get any reflective sound from them bouncing off the front wall and back at you. So try and point them down as far as you can without pointing them at your ears.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • eclypse
    eclypse Posts: 595
    edited October 2003
    Umm.. ok forget that.. hehe. I thought you were using something like the Rti38's.. You have the 30's.. diffused sound should be fine the way you have them.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • Airplay355
    edited October 2003
    thanks, i left them the way they were
