about to hook up a PSW505--need a little help
dl090465
dl090465 Posts: 212
Hello Everyone,
I am about to hook up a PSW505 on the wall where my FXi30 surrounds are, far from the receiver. I want to use the speaker wires for signal. In this case, do I set my receiver to LARGE rather than small and let the crossover in the PSW505 do the rest when it outputs to the FXi30's ???
Thanks for any input,
Dave
Room 1:
ONKYO TX-SR608
Polk Complete RT 5000 System
Polk RT3000p's Front
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk RT2000's Front Someone Please Sell Me Some RT3000 so I can have a second RT5000 setup !!!!
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear
  • packetjones
    packetjones Posts: 1,059
    edited February 2010
    Just to make sure I understand the question. You are wanting to connect the sub to the speaker wire running to your surrounds?
    As far as i know to use the high level inputs on the sub. it would need to be the connections for your fronts not the surrounds. i could be wrong though. Soem others should chime in shortly to clarify.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • dl090465
    dl090465 Posts: 212
    Yes, I want to use the surrounds for my signal so as to not have to run any additional wires....my receiver is a 7 channel receiver and the power output is the same on all seven channels....
    hopefully someone can tell me if this is feasible!!!!!
    Thanks!!!!
    Room 1:
    ONKYO TX-SR608
    Polk CS1000p Center
    Polk FX 1000's Rear
    Room 2:
    ONKYO TX-SR608
    Polk CS1000p Center
    Polk FX1000's Rear
    Polk PSW 120 front
    Polk PSW 505 rear
