Conrad Johnson PV-5 Tube Preamp
Lack of remote is my only issue with these great vintage pieces of gear. Call me a lazy a$$ if you want, however I've come to appreciate the value of a remote. Russman's long stick with a suction cup on it does work, but the novelty quickly wears thin!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I have one and used it with a CJ M50. Don't expect tight bass or razor sharp highs, but the midrange makes up for it ten times over. Smooth as butter. Female vocals are to die for. More ambiance than you could ever want. Replacement parts particularly capacitors are non existent. Might check with CJ support. Some of the original caps were the best at the time but could not hold up over time.
Could have done without the tape dubbing. Extra switch contacts that can corrode. -
This is a relatively old thread (12 months), but I ended up buying the PV-5 mentioned with the original poster's help, sending it out to Bill Thalmann at Music Technology for a complete upgrade, and have been enjoying stellar sound waaaay beyond my $1,300 investment (unit, mods, tubes) since. There's more about it in my thread at . . .
http://www.polkaudio.com/forums/showthread.php?t=96881&highlight=conrad+johnsonVTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
