binding posts for monitor 10
tonyr1
tonyr1 Posts: 103
edited February 2010 in DIY, Mods & Tweaks
I'm doing the x-overs on my monitor 10's and might as well put new binding posts in....need some suggestions . need something that will fit without much **** around, I'm new at this . I don't even know how to solder!!:eek:
Post edited by tonyr1 on
  • anton.chigurh
    anton.chigurh Posts: 239
    Vampire binding posts come highly recommended.
    I just received some Vampire 1.5HEX (14.35/assembly) from Sonic Craft for my Mon. 7Bs along with caps & resistors to do the crossovers.
  • NJPOLKER
    NJPOLKER Posts: 3,475
    I'd go here to buy Cardas or the Vampire posts.
    http://soniccraft.com/products/connections/bindingpost.htm
  • tonyr1
    tonyr1 Posts: 103
    thanks, will check them out.:)
  • george daniel
    george daniel Posts: 12,096
    Vampire BP-hex
  • snowfiend131
    snowfiend131 Posts: 2
    I stumbled upon this thread looking for binding post information for my Monitor 10's. I hope someone can answer a related question.
    I have a broken binding post, and would like to replace it. How easy is it to replace using one of the Vampire posts mentioned above? Can anyone provide some basic directions? Any help would be greatly appreciated. I am tired of using a pair of vice grips to hold the speaker wire to the post!
  • kcoc321
    kcoc321 Posts: 1,788
    It will take about 15 minutes and is pretty easy. I would replace both posts and that speaker, and on both speakers, if yo plan on keeping them awhile.
    Probally the hardest part is cleaning out the the glue inside the "Cup".
    you take out the Xover (disconnecting drivers of course.
    Squeeze the small tabs on he white plastic clips holding the board to the cup.
    Gently rotate the Circuit board up so you have access to the back of the binding post.
    Clean out the hot glue covering up the nuts of the binding posts.
    Unscrew the old posts.
    Screw in the new post with the connectors remounted on them.
    Reverse process.
    CRANK IT UP :D
  • snowfiend131
    Thanks for the installation info. Does the length matter of the binding posts matter much? Vampire BP Hex or Vampire BP Hex 1.5?
  • kcoc321
    the regular size is fine. it only going thru 1/8" plastic
  • anton.chigurh
    I've got the 1.5 Hex, but both work fine.
