I want to build a tube phono Pre
ben62670
ben62670 Posts: 15,969
edited March 2010 in DIY, Mods & Tweaks
I am looking to build a phono pre on a very limited budget. I am thinking http://glass-ware.stores.yahoo.net/aiphpcb.html . Any other ideas in a similar price range would be appreciated.
Ben
Ben
Post edited by ben62670 on
    Toolfan66 Posts: 18,165
    edited February 2010
    I should be getting a custom built tube pre this week to borrow for a few days.
    I haven't seen it yet but everybody that has said it's the ****.
    Gary from intrinsic sound built it and wants $1200 for it.
    I say do it if anybody here can you can.
  • ben62670
    These things are paint by number. You can easily do it too. If I were you I would look into building one yourself. The down fall for me is the cases. I know you can build them no problem so you are ahead of the game.
    Ben
    Ben
    I can build you a case just tell me what size, If I make it out of aluminum it would be nothing for you to put the holes where you want them.
    On a side note I need glasses, I just saw you said phono pre, I was talking about a pre/amp:)
    mhardy6647 Posts: 35,208
    No experience with the boards at the link posted; they look rather complex (generally not such a good thing IMNSHO). They certainly look nice, though.
    The basic RCA circuit sounds very good but can be a bear to get quiet. It is based on the 7025/12AX7 -- not the most exciting high-gain dual-triode, but certainly a venerable candidate for vacuum tube MM phono preamps.
    You can see it in, e.g., http://www.pmillett.com/tubedata/RC20.pdf (note: this is a 22 MB D/L!) see page 412 of the manual (which is pg. 414 of the PDF file).
    The Bottlehead Seduction is a nice sounding phono preamp kit (point to point rather than on a PCB) but 1) gain is a bit limited and 2) it isn't so inexpensive anymore. This is the one I use (so, yes, I am a bit biased).
  • fbm211
    fbm211 Posts: 1,488
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • bikerboy
    bikerboy Posts: 1,235
    Hi Ben,
    check out hagerman coronet II. I think a complete setup is about $400 but the schematic is online I believe.
    http://www.hagtech.com/cornet2.html
    I thought I had saved other lower priced phono pre amp stuff but I cant find it now. I will look some more. Are you going to use a MM cart?
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • ben62670
    edited March 2010
    Ben
  • bikerboy
    edited March 2010
    Looks good Ben but its out of stock. Are you going to make it your self point to point?
    Bottlehead Eros
    CD: DIY Shigaclone
  • ben62670
    edited March 2010
    I will wait for the kit. Not ready for point to point yet.
    Ben
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited March 2010
    Wonder how good this would be for $70. The power supply is about $180.
    http://classixaudio.com/7Cpp1.htm
  • ben62670
    edited March 2010
    Thanks for the link. I think I may just go wit the tetra because it has the PS included.
    Ben
    Ben
  • Polkersince85
    edited March 2010
    I think with the Tetra you still have to supply some of the components and the transformer.
  • ben62670
    edited March 2010
    With the tetra all I need is the transformer, and I have that.
    Ben
  • schwarcw
    schwarcw Posts: 7,358
    edited March 2010
    bikerboy wrote: »
    Hi Ben,
    The Hagerman is very nice. Check out mine that Scompracer built:
    http://www.polkaudio.com/forums/showthread.php?t=88166
    Carl
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2010
    schwarcw wrote: »
    I want that . . . give it to me now!!!:D:p
  • ben62670
    edited March 2010
    I figured out what to build point to point
    http://phonoclone.com/diy-pho3.html
    Very simple and uses the 6DJ8 tubes.
    Ben
