only tweak one thing at a time
  • superjunior
    superjunior Posts: 1,632
    edited February 2010
    ok, I finally got around to trying to pinpoint the issue AND...first attempt I put the original jumper plates back in and presto! - that was the problem. guess I'll have to buy me a nice set of jumpers.
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • hearingimpared
    hearingimpared Posts: 21,136
    Junk those plates Dan they are crap. Radio Shack 12 ga pure stranded copper wire works very well. I used it for jumpers on my 1.2TLs and they sounded fine. I've since moved on the MIT bi-wires. I can send you a few feet of the RS wire if you'd like.
  • superjunior
    Junk those plates Dan they are crap. Radio Shack 12 ga pure stranded copper wire works very well. I used it for jumpers on my 1.2TLs and they sounded fine. I've since moved on the MIT bi-wires. I can send you a few feet of the RS wire if you'd like.[/QUOTE
    thanks Joe, the rs is what I just pulled out of there, maybe I didn't have a solid connection? either way I think I want to try mit bi-wire also so anyone looking for a set of mit terminators check out the fm tommorro. I had one hell of a listening session tonight and learned a couple of things - including how to knock icecles off my gutters without leaving my sound room :D
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • hearingimpared
    hehehe
