polyswitch/ resistor RTA 11T?
zarrdoss
zarrdoss Posts: 2,562
edited February 2010 in DIY, Mods & Tweaks
which one of these wold work to replace the ones in some RTA 11t's?
http://www.parts-express.com/wizards/searchResults.cfm?searchFilter=polyswitch
if not its a 5 ohm or .5 ohm resistor?
thank you!
Post edited by zarrdoss on
  • Bubinga99
    Bubinga99 Posts: 283
    The RXE050 is the replacement for the RDE050A that is listed in the schematic.
    With this particular polyswitch the non-tripped resistance is higher by about a factor of 4, compared to the RXE135 which is the polyswitch part number in most of the other threads discussing polyswitches in 2.3TL and 1.2TL, where 1/2 ohm is the consensus value to use as the replacement.
    1/2 ohm would work fine, but a value larger than the polyswitch non-tripped resistance seems to be preferred in the case of the RXE135 replacement in the 2.3TL and 1.2TL.
    F1nut Posts: 52,294
    Here's a source for poly switches, http://www.mouser.com/Tyco-Electronics/_/N-1z0zls9?Keyword=PTC+Resettable+Fuses
    Right, the RXE135 has a non-tripped resistance of 0.3 ohms. I found that I preferred the sound using a 0.5 ohm resistor, YMMV.
  • zarrdoss
    Thanks, probably go with the resistor this time.
