polyswitch/ resistor RTA 11T?
zarrdoss
which one of these wold work to replace the ones in some RTA 11t's?
http://www.parts-express.com/wizards/searchResults.cfm?searchFilter=polyswitch
if not its a 5 ohm or .5 ohm resistor?
thank you!
thank you!
Post edited by zarrdoss on
The RXE050 is the replacement for the RDE050A that is listed in the schematic.
With this particular polyswitch the non-tripped resistance is higher by about a factor of 4, compared to the RXE135 which is the polyswitch part number in most of the other threads discussing polyswitches in 2.3TL and 1.2TL, where 1/2 ohm is the consensus value to use as the replacement.
1/2 ohm would work fine, but a value larger than the polyswitch non-tripped resistance seems to be preferred in the case of the RXE135 replacement in the 2.3TL and 1.2TL. -
Here's a source for poly switches, http://www.mouser.com/Tyco-Electronics/_/N-1z0zls9?Keyword=PTC+Resettable+Fusesbut a value larger than the polyswitch non-tripped resistance seems to be preferred in the case of the RXE135 replacement in the 2.3TL and 1.2TL.
Right, the RXE135 has a non-tripped resistance of 0.3 ohms. I found that I preferred the sound using a 0.5 ohm resistor, YMMV.Political Correctness'.........defined
President of Club Polk -
Thanks, probably go with the resistor this time.
