Three cheap subs rockin' the house
Early B.
I had an old Yamaha sub sitting in the basement collecting dust. Yesterday I decided to hook it up to my HT system. I positioned it in the front next to the television. I have two other cheap Acoustic Research subs in the rear on each side of the sitting position. I powered on all three of them with the extreme DVD version of T2 and the whole room was shaking. I could feel the vibrations from the subs going up my spine.
But to get three subs hooked up to a single subwoofer out on my receiver, it requires the use of two y-adapters. I would prefer to minimize the number of auxillary connections. Does anyone know where I can find a Y-adapter with one male/three female ends?
Also, the subs are hooked up via RadioShack gold series subwoofer cables. Is there any value in upgrading my cables? If so, what brand is good?
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
One way of doing it would be this, if you have IN and OUTS in your subwoofers you could very well daisy chain your subs. If you need more detailed info, let me know.Money Talks, Mine says Goodbye Rob!!!!
Have you tried calling Redmond Cable? http://www.redcab.com/
This place might also have what you need (they are local to me, but I'm sure they will ship) http://www.electronicplus.com/- Sony 50"A3000 SXRD; Onkyo TX-SR 805
- Polk RTi150 mains; CSi30 center; FXi3 surrounds, R15 backs
- Velodyne CHT-12 subwoofer
