sub with 2 channel
I'm not using any crossover at this time. I'm considering a Bryston, Lyngdorf, or McIntosh in the near future to utilize the room correction available in the Lyngdorf and McIntosh.
The JL's have quite a few controls to effectively blend them with the mains. I used my trusty SPL meter and several test CDS which generate test tones. I must have had four pads of paper strewn about the room while integrating with 1000's of numbers written down:eek:
I still think it could sound better if my room was dedicated. Real world says that won't happen for a few more years.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
pearsall001 wrote: »Hey Gordon, I take it you're still thoroughly enjoying those Mac 501's!!! I'm still working on that MC 402 here though.
/QUOTE]
Hi Phil. I'll keep you in mind this year when I'm ready to get rid of the 501's. The 1.2k's are looking better and better and just about have the better half convinced
A couple more Coach bags and some baubles should just about seal the deal!
Gordon2 Channel -
I've done it both ways. Most of what I listen to isn't that bass intense.
The Proac's do a fine job of most material, so the sub isn't needed.
The Rega's and Hales bookshelf speakers would be better with a sub."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
As others have alluded to, I think it depends heavily on what you are using for speakers. It takes some work to integrate a sub into a 2 ch system, however you do get the option of optimizing the placement of the main speakers and the sub separately. Most people I know have thought they needed dual subs in a 2 ch system were running only one channel into the single sub. Not that there aren't benefits to dual subs, it's just that most people don't integrate and hook-up a single sub properly.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
wrong threadI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
/QUOTE]
Gordon
WOW! Gordon...moving up the chain already? You know it doesn't end with the 1.2K's!!!
Let me know when your ready to make the move. Hopefully the timing will be right for me."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
I love the punch a properly setup subwoofer can provide to a 2.1 system. Many people tend to over-emphasize the bass signal resulting in a sloppy, muddy mess when any amount of volume is applied.Den
Parasound 2100
Parasound 2125
Denon DCM-390
LG BD390V
Martin Logan Preface(x2)
Denon AH-D2000
Bedroom
Adcom GTP-350
Parasound HCA-800II
Panasonic DVD-S54
Denon AH-2000
Polk S4(x4)
ಠ_ಠ -
I've always had a little problem balancing subs for 2.1 music...they're fine in HT...Blend in perfectly at 80hz....but once we go 2 channel I always have to tweak the sub(s)--back them off..to the point where they are just barely audible.
I guess I should add 1 reason I ask is beacuse I may be replacing my RTi8 with Rtia3's. long story explained in different post. So with RTia3 for music--sub or no sub?
cant you turn on or off the sub depending on if you are listening to music or watching movies as well?Sharp Aqous 40" LCD
Onkyo TX SR-507 AVR
Onkyo DX-C390 CD Changer
POLK RTI8 Mains--Cherry
the rest...in process...slowly!! -
I have the RTiA3s as fronts and an Epik Valor sealed sub.
And I would say if you can afford it - you should run a sub with them.
I will qualify that somewhat by saying that the RTiA3s can produce some pretty satisfying bass for music.
In playing with my setup - I have run my AVR in Pure Direct mode which turns the LFE output off to the sub and the AVR becomes a 2-channel setup. And I have on several occassions have put my ear up to the sub just to make sure it was off cuz the sound coming from the RTiA3s seemed pretty full.
So yes, for music you could turn off your sub and I think you'd be surprised at what you can get from the RTiA3s.
You can leave your sub on and if your AVR supports holding different memory configurations, you could have one setting that is for HT (Sub on, Speakers set to "small"), one for Music w/o sub (Speakers set to "Large", AVR set to Pure Direct), or one for Music w/ sub and Mains (Sub on, Speakers set to "Large", AVR set to whatever mode you want-multichannel, PLIIX, Orchestra, Rock, etc).
Then you can simply recall the settings on the fly and pick which one sounds best to you.
But for the RTiA3s a sub does offer that completely filled in low end sound - and for movies you do need a sub to pressurize your room for the scary dangerous LFE effects.
I'm very happy (for now) with my setup.
...back them off..to the point where they are just barely audible.
cnh
...which is the correct level for proper integration into your 2.1 system.Den
Parasound 2100
Parasound 2125
Denon DCM-390
LG BD390V
Denon AH-D2000
Bedroom
Adcom GTP-350
Parasound HCA-800II
Panasonic DVD-S54
Denon AH-2000
Polk S4(x4)
ಠ_ಠ -
Erik Tracy wrote: »I have the RTiA3s as fronts and an Epik Valor sealed sub.
Excellent reply, thank you. Are your RTia3s on stands or shelf? By the way My AVR is an Onkyo sr507 that i am still learning all it has to offer.
Thanks again
-GregSharp Aqous 40" LCD
Onkyo TX SR-507 AVR
Thanks again
-Greg
I have them wall mounted
twin subs help w/integration; the add'l power & reduced distortion doesn't hurt either.
Sometimes the "integration problem" is an XO issue detracting from what are great speakers that have become satilites, hurting w/other issues rather than helping (reducing) dopler effects.
I've discussed this with many people haven't found two agree on XO type: symetrical, asymetrical, 2d order, 4th order, Bessel, LR, butterworth, etc, etc, etc!
I'm currently using the filtering in my SSP w/a single SW.
Allow me to describe a system I had when I single and had the space. XO: symetrical 4th order LR filters. A quad amped system in a big room, high ceiling. Twin subs (dual 12"s) each with their own 2 channel high current amp. Dual 8" driven w/Meridian monos between 60-180hz. Meridian active speakers handling 180hz on up. That system sounded full & effortless at ANY volume setting!Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Twin subs may help with integration if you get them set up right, but assuming that when you say "twin" you mean "stereo" rather than stacked, they're an absolute **** to get set up correctly. One sub with proper research is cake to blend. I've had a few through my setup and never had a problem with blending or lumps. I ended up with that "i have gigantic floorstanders" sound, rather than "i have a 2.1 system."I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
If you take a looks at the specs on the Polk RTi A9, they go from 18-27khz. That's lower than most subwoofers go. Don't know how good they are for 2 channel though.2 Channel rig:
LSi9"s (modified xover's) & HSU Sub
Harman Kardon HK 990 Amp
Onkyo C-S5VL SACD
Music Hall MMF 5.1
Furman Elite 15
HT rig:
HK AVR-745 & Polk Monitor Series -
Hello all,
First post. I've been reading and learning for a while. I even updated my Monitor 10s xovers using the info learned here.
After fiddling with subs for 25 years or so here is my two cents:
Active crossover with a crossover point between 60 and 40hz.
Two subs run in stereo.
Plenty of power, I run mine with two Hafler DH-200s.
Room placement is critical. Corner placement will not produce good results most of the time.
Equalization is good-I have an AudioControl Richter Scale III. It is actually two components in one, a programmable crossover and a six band half octave equalizer with tone generator for each frequency-22.5hz, 31.5hz, 45hz, 63hz, 90hz and 125hz.
And most importantly-remember that many recordings don't contain any information in the bottom octave. The subs will be sitting mostly idle much of the time.
LH -
Not necessarily. As a matter of fact REL Sub-Bass systems are specifically tailored for 2 channel.McIntosh MA-7000 Integrated
Cambridge Audio Azur 840C CD
B&W 805s
Logitech Transporter Wireless Link
Mac Mini Music Server
Furman Elite Power Conditioning
Signal Cable, Magic Power Cables
Signal Cable, Silver Resolution Balanced Interconnects -
I love the sub in 2.1 system... I am sure there are speakers that just don't need addition of a sub and dig deep enough, but IMHO whether you need a sub or not really depends on your speakers.
For example, I have Maggies in my 2-channel setup. These speakers simply do not dig deep by definition. Therefore, I added 15" Velo ULD-15 to the picture and love it. It took me forever to find the sweet spot between speakers and the sub, and only after I got Paradigm X-30 crossover, I got what I wanted.
Also, I would cross the sub at just over lower frequency boundary (at -3dB) of the main speakers (mind it, only for 2-channel setup). A lot of crossover tends to mud the upper range of low frequencies.
Oh yeah, I do NOT use LFE output for the sub or anything like that. 2-channel is 2-channel stereo. My Carver C-1 preamp has 2 sets of outputs: 1 goes to the amp, 2nd goes to the active sub crossover, then to the sub amp.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I've done both the 2.0 and 2.1 for my music setup. I prefer to include the sub. It's not necessary for everything I listen to, but it doesn't hurt either. My thought is why not take some of the load of my Paradigm S8's and let them shine? I let the sub handle anything below 50 Hz.
I guess a sub is ok in a two channel system but very few people set it up like they should. You should only hear it once in awhile and anyone unfamiliar with your system should walk away believing you only have the two main speakers hooked up. Any more sound level than that is unnatural and takes away the beauty of the really important sounds.
madmax
While its true that you should not be able to tell where your mains end and your sub begins, when it comes bass SPL with certain types of music for example Rap a sub is part of the music I don't think you can dial a sub in perfectly and then leave it alone, I actively change the settings all the time. IMO there is no perfect setting while I've found I don't need to touch the cross over point, I m constantly changing the Gain on the sub, because the demands of music are dynamic. Some times I just need more bass and other times less.Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Pioneer PD-5010 CD player
Sennheiser HD 650s
Maverick Audio Tube Magic D1 DAC
AMD Phenom II 940 @ 3.8 prime stabel
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
Creative X-fI Titanium Fatal1ty -
madmax
Setup & seemless integration are key factors. However, when properly done...look out!!! It doesn't get any better for musical enjoyment. And don't forget it's not all about the pipe organ notes."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
madmax
Well said madmax and I just accomplished this on a small scale.
Added a Mission 700ASi sub to my 2-channel rig (nothing fancy, 150 watt class D power and a 10" subwoofer) just to see how it sounds. Crossover point is 50Hz and it goes down to 30Hz.
My goal is to get another VMPS sub, but I need to save more pennies. -
If someone one had told me 5 years ago I would own subs I would have called them a liar. I have A9 towers and 2-DSW PRO 400 subs set up as a dedicated left and right. Don't get me wrong , the 9's sound fantastic , but the subs complement them so much is un real. I fired up the system once and intentionally left the subs off. Holy crap!!!! Where did the music go?? LOL!
Gotta say that I was pretty pleased without a sub in my system. But I recently bought a pair of bookshelf speakers from a manufacturer that shall not be named (but rhymes with schmlorel). As part of the deal I got a nice little powered sub. I waited about two weeks before I installed it. I didn't feel like I was missing bass before the installation, but I was blown away by what it added to the system. Having said that, I still haven't found the perfect positioning for the sub. It's just not sounding like it's part of the performance yet (I listed mostly to rock). But I think it has to do with where it sits in my room and where the crossover point is. It has a tunable crossover. Right now it is set to 65Hz. I think I'm closing in on that front, though.
I agree, I like dual subs in a two channel arrangement.
I'm going to do 3 pair of mains and 4 subs in a 2 channel system, but that's just me...
:cool:TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
:cool:
Wow!!!!!!!! Awesome system!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Erik Tracy wrote: »I have them wall mounted
What center is that and what brackets are you using to mount it on the wall?Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk TSi500s Vr3 Fortress modded
polk CS20 center channel Vr3 Castle modded
polk Owm 3 surrounds
polk PSW505 -
Slinger182 wrote: »What center is that and what brackets are you using to mount it on the wall?
Polk CSi3 mounted on a B-Tech 15
http://www.btech-usa.com/bt15.html
