RTA 11TL question
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited February 2008
    There's no right or wrong tweeter. It's all a matter of personal taste.
    The analogy that newer must be better is not always true. If it were, we would all be listening to lsi's instead of the vintage polks.
  • avguytx
    avguytx Posts: 1,628
    I'm recommending $12 worth of caps that I've been using on my sl2000's for over a year instead of over $200 for new tweeters that he has no idea what they will sound like or if he will like them. I know what I would do if I was in his position.
    Show us a link to something that says putting caps in series right at the tweeter when they already HAVE crossovers. All you are doing is changing the crossover point and wreaking havoc on the values of the stock crossover. There is no scientific method to what you're doing. I called a few buddies in the last few days asking about this and they first reaction was, "they added what where???" Two of these "buddies" are from PSB and Sunfire.
    For the sake of credibility, show us ALL where it says you can simply add a cap inline at the tweeter and what those results are supposed to yield.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    by the way, can you tell if my tweeter is an SL2000 by just showing a picture? I know for sure that it is not an SL3000 because the text is horizontal and it says Silver Dome Coil. How does the RD0 look like? Anyone please with a picture?
    Here you go.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • avguytx
    Here's a pic of the RD0-194's in the SDA 1C's I had.
  • aud10n3wb13
    aud10n3wb13 Posts: 84
    Here you go.
    Hey, those are cool feet. How did you make 'em? ;)
    F1nut Posts: 51,760
    Wow, that's quite a stretch going from a tweeter to an entirely different speaker. Got to be one of the worst analogies I've read.
  • MillerLiteScott
    Scrap oak, power tools, black spray paint and clear poly. Quite simple actually.
    I did not like the way the original bases looked. YMMV.
  • candyliquor35m
    avguytx wrote: »
    I did not make the initial recommendation and can't find the post but I tried it and it works. I'm glad that you are researching the science behind it because that needs to be done also. I've done the testing and experienced the end result. I don't have a problem with spending $3 to see if something works. That's a no brainer.
    You work with electronics so it's important for you to understand the why and how. All I care about is the end result.
  • aud10n3wb13
    If it's ok, can you take a closer pic so I will have an idea how you mounted them? Also, different angles of pictures please :p
    Thanks again. ;)
  • aud10n3wb13
    From what I understand you bought RD0 and you were not happy with it. If it's still with you, can I purchase the pair like $70. Please pm me.
  • candyliquor35m
    I just sold them locally for $60 but told them they could bring them back if they don't like them. I kind of like having a pair around to do side by side comparisons with but the guy wanted to try them out so I sold them rather than having them lay around collecting dust.
  • MillerLiteScott
    Thanks again. ;)
    Her are pictures of my DIY outriggers and how they are attached.
  • aud10n3wb13
    Very nice!!! How did you make the edge? Did you use a router?
    Thank you so much. :)
  • MillerLiteScott
    Yes I did.
  • PolkClyde
    PolkClyde Posts: 662
    edited July 2008
    I Just ordered 8 tweeters upgrade from polk for my 1.2'S Eric told me it was the upgrade for the SL2000 he said they are much better than the old SL2000. Well I like my highs or bright sounding speakers with Real good bass. But I must say the The E-mit tweeter probably would blow them(sl2000,sl3000) out of the water but the E-mit isn't a Polk speaker(tweeter)
    PolkAudioClyde
  • PolkClyde
    edited July 2008
    I'm going to get in trouble now........ hope not. :)
    PolkAudioClyde
  • kniowsk1
    kniowsk1 Posts: 33
    edited February 2010
    Getting some 11TLs in a few weeks...
