Problem with PSW125
smurph
I've had the PSW125 for about 4 years. It's attached to my Sony STR DE 698 by a good RCA cable from the Sub Out to Line In on the Sub. It has worked very well for most of the time.
Currently it is very overpowering and rattles quite a bit. Nothing has changed in my setup. It has done this once or twice before. When it happens I start checking everything and testing. It makes no difference. So I change the settings on my receiver and disable the sub for a week or two.
I believe it's a problem with the electronics in the sub. I can make the sub drasticly change volume by just tapping or touching the volume knob. If I move the volume up and down it will make all sorts of vibrations.
Any suggestions on fixing the issue or cleaning the volume setting?
I also have two Polk R30's for R and L.
I have an old KLN ?? for Center and SR, SL.
Steve
Steve
Post edited by smurph on
id look for a replacement amp. or im sure the switch can be replaced probably by you if you have a soldering iron. either way its an easy fix
You definitely need to get that checked out.My Home Theater:
Display: 61" RCA HD DLP
A/V Receiver: Onkyo TX-SR606
Fronts: Polk Audio Monitor 60s
Center: Polk Audio CS2
Rears: Yamaha YHT-790s--The Tower Ones
Sub: Polk Audio PSW125
Blu-Ray Player: Samsung BDP-1500
Gaming Systems: Xbox 360 w/HD DVD player & Nintendo Wii
Satellite: DirecTV HD DVR
The Bed Room:
Display: Vizio 32" HD LCD
Blu-ray Player: Samsung BDP-1000
Audio: Yamaha HTib
Gaming Systems: Sony PS2 and Nintendo Gamecube -
Call Polk CS smurf, they are second to none and will have you back up and running in no time. Welcome to Club Polk.
-Jeff
1-800-377-POLK (7655)
9AM-5:30PM EST Mon-FriHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
