Surroundbar hookup with existing front speakers
Canadian12
Canadian12 Posts: 16
Folks,
I've looked for this post already, so my apologies if this is redundant. I'm about to purchase a surroundbar and when I'm reviewing the manual's, it looks the surroundbar is intended for rear and front speakers.
I already have RTI12's for front's and just want the surrounbar for the rear channels.
I'm sure I can avoid using the front's but has anyone experienced this, or is this a non-issue?
Thanks,
Vision: Sony Bravia 52" XBR
Power: Onkyo TX-SR876
More Power: Onkyo M-282
Front's: Polk Audio Rti12's ;)
Sub: Polk Audio DSW Micropro 4000 :eek:
Source: PS3 80GB
Post edited by Canadian12 on
  • jimbo1421
    jimbo1421 Posts: 772
    edited February 2010
    The SurroundBar 42" and 50" have front, center and rear channels. The SB center would not be timbre matched to your RTi12s, so that would not work well. I assume that you want to just leave the front channels of the SurroundBar disconnected. As an experiment I once tried my SurroundBar 42" with the front and center channels turned off. This left a sound stage of ambient noises that was, at most, 180°, with most of the sound coming from the front 90°. I tend to think that you would be better off getting a matching center as part of a 3.1 system.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    I would have to agree with the above post that the SurroundBar wouldn't be ideal as a surround speaker. Look into a set of FXi5's if you want to get some surrounds. Or look into a CSi5 for your center, I would get the center first, esp. if you do any movie watching. Hope this helps.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Canadian12
    Gents,
    Thanks very much for the reply. Probably saved me a $700 experiment that may not have turned out......!
    Just trying to save the wiring job for the rear speakers, but I suppose that the lazy way anyhow.
    I like the suggestions for Center channel. Any thoughts about the Rears? Bang for the buck?
    Thanks again
    Source: PS3 80GB
  • wutadumsn23
    -Jeff
    Or even the TC80i's if you want to go the in ceiling route.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
