Surroundbar hookup with existing front speakers
Canadian12
Folks,
I've looked for this post already, so my apologies if this is redundant. I'm about to purchase a surroundbar and when I'm reviewing the manual's, it looks the surroundbar is intended for rear and front speakers.
I already have RTI12's for front's and just want the surrounbar for the rear channels.
I'm sure I can avoid using the front's but has anyone experienced this, or is this a non-issue?
Thanks,
Thanks,
Vision: Sony Bravia 52" XBR
Power: Onkyo TX-SR876
More Power: Onkyo M-282
Front's: Polk Audio Rti12's
Sub: Polk Audio DSW Micropro 4000 :eek:
Source: PS3 80GB
Source: PS3 80GB
The SurroundBar 42" and 50" have front, center and rear channels. The SB center would not be timbre matched to your RTi12s, so that would not work well. I assume that you want to just leave the front channels of the SurroundBar disconnected. As an experiment I once tried my SurroundBar 42" with the front and center channels turned off. This left a sound stage of ambient noises that was, at most, 180°, with most of the sound coming from the front 90°. I tend to think that you would be better off getting a matching center as part of a 3.1 system.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
I would have to agree with the above post that the SurroundBar wouldn't be ideal as a surround speaker. Look into a set of FXi5's if you want to get some surrounds. Or look into a CSi5 for your center, I would get the center first, esp. if you do any movie watching. Hope this helps.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Gents,
Thanks very much for the reply. Probably saved me a $700 experiment that may not have turned out......!
Just trying to save the wiring job for the rear speakers, but I suppose that the lazy way anyhow.
I like the suggestions for Center channel. Any thoughts about the Rears? Bang for the buck?
Thanks againVision: Sony Bravia 52" XBR
Source: PS3 80GB -
wutadumsn23 wrote: »Look into a set of FXi5's if you want to get some surrounds.
-Jeff
Or even the TC80i's if you want to go the in ceiling route.
-JeffHT Rig
Blu-Ray- 80 GB PS3
