Tone Controls
2
  • headrott
    headrott Posts: 5,496
    edited February 2010
    treitz3 wrote: »
    Now a note to those who may not know.....IME, I have found that a defeat of all tone controls bypasses circuitry and even though no tone controls were used? When defeated, the sound improved and most all aspects got clearer, smoother and more realistic. With my own audio journey at least.
    Now, when I finally got a pre that had no tone controls whatsoever? That's when the real sound came in to fruition. With proper amplification [and a little bit of tubes in the mix...], my sound whether it be frequencies or overall sound has improved dramatically.
    My point is that though some of you may consider tone controls as an improvement, when you reach a certain point in your audio journey tone controls can be detrimental to the end result as to what hits your ears, instead of a perceived improvement.
    Happy listening either way. ;)
    Agree with the above 100%.
  • steveinaz
    steveinaz Posts: 19,546
    There's 2 reasons to use tone controls:
    1. Equipment or room shortfalls
    2. Poorly engineered recordings (overly hot treble, ect)
    Used correctly, and of good design, they can help some limited situations, but they shouldn't be a way of life--or used because you have a tonal sweet tooth. #1 above can be addressed, #2 is a little tougher to get around, but I would say that maybe .5% of my music library is so out of whack, tonally, that it could possibly benefit from the use of tone controls.
    mhardy6647 Posts: 35,230
    Tone controls are of the devil.
  • 98Badger
    98Badger Posts: 317
    It really comes down to personal preference just like everything else in this hobby. When I first started, I used tone controls and EQ all the time. After upgrading my speakers, it became less necessary (to me). I was worried about going to a dedicated preamp without tone controls a while back, but as it turns out, I don't miss them at all. It always seemed like when I fiddled with the EQ to fix a particular song or type of music, it would mess things up for other songs. I'll be the first to admit this could be the result of adjusting the wrong frequency bands. Now, I doubt I'll go back to either EQ or tone controls.
  • Cpyder
    Cpyder Posts: 514
    Let me know if this is true: If a recording is already clipped, adjusting the EQ cannot restore any data outside of the clipped zone. The sound waves will still be cut off and all you'll end up with is a more quiet clipping sound. This picture should demonstrate what I mean:
    heiney9 Posts: 25,497
    Cpyder wrote: »
    Asked an answered in post #4. You can NOT eliminate clipping if it's part of the recording, unless you have the master recording, very expensive and sophisticated software and a lot of knowledge. Even then depending on the recording it may not be able to be saved.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    heiney9 wrote: »
    Actually, that depends on when the clipping occurred. If it happened (as it usually does) at the mastering stage, then yes, it can be corrected, by re-mastering. If it happens at the recording stage, it's game over...no fixing that, ever.(short of re-recording the clipped section)
    I can think of one recording in particular, where a vocal line got distorted, not because of riding the fader too hot, but because the voice was so powerful, it literally distorted the microphone diaphragm. It was an otherwise perfect take, so it was kept. The distortion sounds like an added effect, unless you know what it is, and are listening for it.
    Less, I assumed he was talking after the fact about a consumer CD he purchased and wants to "unclip" at home using an eq/tone controls. Not at the mastering level. If you see his other posts, he's a young college student who is still learning the ropes of audio.
    Let me guess Dream Theater - Burning My Soul :D:p
    Or maybe it's Lines In The Sand
  • LessisNevermore
    heiney9 wrote: »
    Gotcha.
    heiney9 wrote: »
    Ooooh, you're good.:eek::D
  • Mon40CSMM10
    Mon40CSMM10 Posts: 161
    I recently added a passive subwoofer to a secondary system, and my tests show that there is a valid and necessary use for both the bass and treble tone control adjustments. Otherwise, the passive subwoofer may provide too much boomy bass and the satellite type mains may not be able to project enough through that boomy bass.
    Secondary system in use:
    * 6 ohm passive subwoofer (originally from a cheap Venturer home theater system but the integrated receiver/DVD player had broken). Connected to the receiver's B-speaker outputs, positive speaker wire to left output and negative speaker wire to right speaker output. Scosche Low Pass crossover also attached to the positive wire.
    * Technics SA-GX170 stereo receiver.
    * KLH TW-90B 8-ohm satellite mains. Scosche XOHP High Pass crossover is also attached to the positive wire of each of the satellite main speakers.
    (Note: The use of the Low Pass and High Pass crossovers helps ensure a smoother transition from the mains to the subwoofer, for music and also 2.1 channel movie usage. Although these are typically car audio components, their use in home audio seems legitimate as well.)
    Tone control adjustments (center position is dial pointer at 12 o'clock):
    * Bass dialed all the way down to between the 8 o'clock and 9'o clock position. This reduces how low the subwoofer can reach but also removes the boomy quality of the front firing/rear ported passive subwoofer.
    * Treble is increased slightly to between the 12 o'clock and 1 o'clock position.
    This is typically a lower volume setup in a secondary room (it rarely gets turned up past 2 out of a maximum of 20 on the volume dial), so it's more important for the system to sound clear at lower volumes and have a relatively full frequency range instead of the subwoofer being able to hit really hard and really low.
    So, that's my justification for usage of tone controls.
  • Cpyder
    Cpyder Posts: 514
    heiney9 wrote: »
    Yeah, I don't own a recording studio... yet. :)
  • dougy
    dougy Posts: 182
    edited March 2010
    Personally, I wish more two-channel gear had good tone controls like back in the good ol' days. And to make it even better, they should be remotely controlled. As long as they can be bypassed, what's the down-side, other than the cost? Quality parametric EQ can be a real room tamer, too.
    As for the distortion tone controls add, I've never heard it, unless you are talking about driving your amp into clipping because of the boosted level -and that's not a fault with the EQ circuit. What I have heard, is hiss from some tone control and EQ circuits, especially if much treble boost is used. And sometimes, even with the contols at the neutral positions, I've heard increased noise. So of course that's always a bad thing.
    Still, tone controls have their place and can be very useful tools. After all, we all have recordings that have too much or too little bass or treble. A little boost or cut can make it much better sounding and isn't that what it's all about?.
    THE MAN-CAVE 5.1 CHANNEL A/V RIG
    Sony KDS-60A3000
    a/d/s/ HT-400LCR (3)
    a/d/s/ HT-300 (2)
    Velodyne DLS-4000R (2)
    Pioneer Elite VSX-55TXi
    Pioneer Elite DV-47Ai
    Sony BDP-S300
    Sony SLV-779HF
    DirecTV HD sat. receiver
    MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
    Adcom GFA-5500
    Bose 901 Series VI
    NAD C-165BEE
    Slim Devices Squeezebox Classic
    TEAC CD-RW890
    Technics SL-BD20D w/ Audio-Technica P34
    Akai HX-A3X
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2010
    dougy wrote: »
    While I agree with your sentiments for the most part. There is a reason that high end gear manufacturers for the most part did away with them. I believe that room treatments would better tame bass and treble problems. I sometimes wish I could boost my bass response but the reason for that is there are some null spots and trapped bass response in my speaker side corners. I'm working on some room treatments of my own to help this along.
  • Fongolio
    Fongolio Posts: 3,516
    edited March 2010
    I listen to a lot of older music on vinyl from the 60's and 70's and have found the eq'ing done at mastering is all over the map. I found that original releases are generaly better mastered than subsequent releases. I find tone controls very helpful for compensating for bad or less than top notch mastering. What I don't understand is why some engineers drastically alter the eq'ing of some great originals. For newer music and digital in general I rarely touch my tone controls but for older stuff I find them essential.
    Ok, fire suit is on. Flame away.
    PS...Robert Ludwig masters on vinyl and Steve Hoffman on digital are some of the very best to my ears. Set tone to defeat and enjoy.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • ben62670
    ben62670 Posts: 15,969
    edited March 2010
    KISS More stuff in the signal path the more that the SQ is degraded. When I first started messing around inside higher end gear I was shocked to see how few a component was in there.
    Ben
    Ben
  • hearingimpared
    edited March 2010
    Fongolio wrote: »
    You mean Fire Retardant Suit!!!:D You're dead on with Ludwig and Hoffman. There are several companies that do a bang up job like those two fellas.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2010
    Tone Controls drool
    never forget though
    Tubes Rule.
    that's it.
    I am RT1
    who put the pigweed in the mulligan stew????
  • reeltrouble1
    edited March 2010
    btw this one echoes.
    RT1
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited March 2010
    My amp has tone controls, but the knobs do not sport my finger prints. IMHO the three band tone controls that come on most units are too crude to be of much use.
    Back when vinyl ruled, there were a lot of equalizers around too. The best ones, 10 or 12 bands, served a purpose of equalizing the speakers to the room particulars. For example, if the room has a lot of hard surfaces, the tweets may be toned done a bit to cut back on undesirable reflections. The best equalizers came with a pink noise generator and mike to assist with calibration. Some self calibrated.
    Like others said here, you cannot equalize music that came clipped or otherwise distorted. Garbage in = garbage out (only louder!).
  • reeltrouble1
    edited March 2010
    balance controls were also useful back in the day for TT as the grooves could be quite a ride for the stylus and it was not uncommon for it to ride left or right of center.
    RT1
  • hearingimpared
    edited March 2010
    RT1
    That is correct but the improvements in stylus technology i.e. line contact stylus and fine contact stylus have made this a past necessity.
    In my best Mexican bandit voice, "I don't need no stinkin' balance control!"
    BTW "tone controls drool, tubes rule" WAAAAAAAAAAAAA!!!
  • concealer404
    concealer404 Posts: 7,440
    edited March 2010
    I heard that tubes WERE tone controls. :p
  • hearingimpared
    edited March 2010
    They can be! Rolling, rolling, rolling on the tube express.
  • sucks2beme
    sucks2beme Posts: 5,691
    edited March 2010
    Most built in tone controls are completely useless. Even better ones have their limits. Like others have noticed, adjusting for something I want normally
    will do bad things in ther places. The car is a different story. Hard to
    reposition speakers there!
  • reeltrouble1
    edited March 2010
    Old Addage from Old Guy........................an audio signal can only be degraded by any device within its signal path, at best it might pass relatively unscathed. Tubes do change the signal, love those little electrons and getters and such.
    RT1
    SCompRacer Posts: 9,121
    edited March 2010
    AudioFilet wrote: »
    If you use tone controls, does it make you a bad person??
    No, it's more an issue of poor judgement.:D
    Hey Joe, if I have a balance problem, I just lean right or left.
  • pploeser
    pploeser Posts: 88
    edited March 2010
    I don't see anything wrong with using tone controls to compensate for less than ideal room acoustics or speaker placement... or even poor sounding recordings. After all, why not use them to make your music sound the way you like it? That's what artists and recording engineers do in the studio right?
    Having said that, I do agree that you can't use tone controls to completely resurrect characteristics that have been stripped from the original recording.
  • reeltrouble1
    edited March 2010
    I am not sure if an analogy between an artist and an audio reproduction device is a comparison of note. The pots in the controls further degrade the signal on its trip. Do you have any experience with audio gear developed without tone controls?? Any thoughts on why certain manufacture's make sure to include tone defeats on some of their gear?? Just asking, as you say, you can use them all you want if it makes you like your system.
    RT1
    edited March 2010
    Tone controls add unecessary circuits which in turn create noise which in turn ultimately do more harm than good. Even the so called "direct" button or buttons that supposedly defeat the controls are no good as they add the same type of noise and distortion as the controls themselves.
    Speaker A/B switches are evil as well. It's all about what trade offs you are willings to make in your particular situation and what you want to accomplish in the end.
    For me I want the simplest, most revealing, highest resolution system I choose to afford. There are drawbacks to this kind of system, no two recordings ever sound alike, poorer recordings meticulously show their flaws but the big reward is well recorded music sounds spectacular!!!
    Not everyone enjoys so much truth in their systems.........to me the truth is the most important, even if the truth is hard to listen to at times.
  • Hillbilly61
    edited March 2010
    pploeser wrote: »
    I don't disagree. Equalizers are the tool for the job. They adjust the volume per frequency range much more finely than the two or three knobs on an amp can ever do.
