Tone Controls
Cpyder
Cpyder Posts: 514
edited March 2010 in 2 Channel Audio
So after much consideration, I've realized that in most cases, tone controls are evil. For example, with much of today's music, the recording studio loves to max out the loudness of their tracks. In this case, turning up the bass, for example, on an equalizer causes very audible clipping regardless of the volume of your system. But what about lowering the volume of maxed out tracks? Can this remove clipping? I know you're still altering the original signal, but what if the original was mastered horribly. (In some cases, with the volume on the track already causing clipping)? In this case do tone controls produce a "better" sound? (at least to your ears)
«13
  • vc69
    vc69 Posts: 2,500
    edited February 2010
    No. You can't fix stupid.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • polkatese
    polkatese Posts: 6,767
    I an ideal world, tone control is not needed. For the same reason, in an ideal HT environment, there is no need for Audyssey MultiEQ. But they serve its purpose.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    heiney9 Posts: 25,714
    Told ya! And no you can't just lower the levels to "fix" the high levels the recordings are made at. They use compression to make all the sounds (soft and loud) play at the same output level.
    It's a travesty how many recordings are made today.
  • steveinaz
    steveinaz Posts: 19,547
    There's no way to get back crushed dynamic range. You can give your approach a shot, but I doubt you'll be satisfied with the results. "Better Sound" is not likely, you'll simply be messing up something worse than it already is.
    treitz3 Posts: 20,366
    What's a tone control? :D
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    I don't even have a balance control. It is what it is. Sometimes it sounds incredible sometimes it sound like S. Garbage in garbage out Bliss in bliss out.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • bigred7078
    bigred7078 Posts: 477
    you can't polish a ****...
    Pro-ject RM-9.1 w/ Grado Sonata 1 -> USP-1 -> RPA-1 -> Vienna Acoustics Mozart Grands
  • MillerLiteScott
    You can't pick one up from the clean end either.
    F1nut Posts: 52,406
    Hehe.....
  • joeparaski
    joeparaski Posts: 1,865
    I've always found this discussion funny. Some of you guys are worried that a tone control will alter the sound the way the artist meant it to be, despite it being already butchered by the fine folks in the mixing/recording studio.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Face
    Face Posts: 14,340
    Tone controls add distortion, nuff said.
  • jz0h4d
    jz0h4d Posts: 33
    Musicians use tone controls all of the time. Guitar and bass amps all have tone control circuits and they do get used. Recording desks have EQ . The mic selected to record any source has a frequency response that the recording engineer considers when determining which mic to use on each instrument. The mastering process and again EQ is applied.
    When I'm trying to pick out(transcribe) bass lines from CD's guess what I use the EQ to raise the level of the Bass. If I'm trying to pick out acoustic guitar runs I might lower the Bass EQ.
    So no there is nothing evil about EQ. It is a tool for you to use or not use.
    F1nut Posts: 52,406
    Face wrote: »
    Grand slam!
  • pearsall001
    pearsall001 Posts: 5,400
    Face wrote: »
    Kinda like tubes.
  • Conradicles
    Conradicles Posts: 6,435
    hehe
  • hearingimpared
    hearingimpared Posts: 21,136
    Kinda like tubes.
    Shed ep you wascally wabbit!
  • joeparaski
    Face wrote: »
    Yeah right, and it's really noticeable too.
    Joe
  • joeparaski
    Grand slam!
    Sure does, when I bring up the highs a bit the noise become so unbearable with all that distortion...I really don't know how anybody can listen to that. Add a bit of bass or midrange and the music becomes undistinguishable from a diesel engine.
    Joe
  • Face
    Face Posts: 14,340
    Do you have any gear with a tone control bypass? On some gear it does make a subtle difference.
    As for tubes, they add even order distortion, which many find pleasing. Odd order distortion is what hurts your ears.
    Kinda like tubes.
    No, tubes add a different kind of distortion (2nd order rather than 3rd), not really more, but it depends on the circuit design and the tube used. Most tubes are more linear than most transistors. Non linearity is defined as distortion.
    Negative feedback is used to make a circuit more linear and negative feedback adds even more distortion to a circuit. Negative feedback is used more in solid state than in tubes, but some push/pull tube designs use negative feedback, generally less than an equivalent SS circuit. There are some **** tube designs out there which add distortion.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Tone controls? I don't need no steenkin tone controls.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • lanchile
    lanchile Posts: 560
    Tone controls suck
    I second that!;)
    Make it simple...Make it better!
  • lanchile
    lanchile Posts: 560
    Face wrote: »
    ...and change the original sound. I never liked tone controls or balance.That is why in my diy amps I never use them (and never will).
    Ok, ok, ok.....honestly?
    Tone controls are good for some systems. When the system is lacking or accentuating certain frequencies or in some cases close to clipping at what many consider "normal listening levels"? Eh, tone controls may [usually do] make the sound, well sound better to the listener. No disrespect to those who are in that place within their own personal audio journey......trust me, I've been there. ;)
    That said, when a system reaches a certain level of performance / reproduction? Tone controls are evil "knobs of sin" to the audiophile. What they do is add distortion to the original signal, add an unnatural balance to the overall spectrum of frequencies and almost 95% of the time [IME] boost just a certain frequency which also alters that of the frequencies closest to the frequency the manufacturer is trying to boost in the first place.
    What I'm trying to say is that.......let's say a manufacturer makes a bass "boost" at a frequency of [just for the sake of discussion] 65Hz, ok? This affects the frequencies around that boost as well. Depending on the manufacturer, the frequencies affected could be as low as 45 Hz and as high as 75 or higher Hz. That's a big part of the spectrum of frequencies affected by that one tone control.
    That's just the bass control.
    In other words, you may want to boost [as a listener] the frequency of a bass guitar. The end result of you adjusting the "control" may affect the drums, but the Cello, Basson, French horn, Tuba, Kick drum, Tympani, and what many desire for some punch.....the Tom drum.
    Why would you want to affect all of these instruments and add distortion or an altering of the original signal when all you want to do is boost the bass guitar? Seems a little bass ackwards to me.
    Now a note to those who may not know.....IME, I have found that a defeat of all tone controls bypasses circuitry and even though no tone controls were used? When defeated, the sound improved and most all aspects got clearer, smoother and more realistic. With my own audio journey at least.
    Now, when I finally got a pre that had no tone controls whatsoever? That's when the real sound came in to fruition. With proper amplification [and a little bit of tubes in the mix...], my sound whether it be frequencies or overall sound has improved dramatically.
    My point is that though some of you may consider tone controls as an improvement, when you reach a certain point in your audio journey tone controls can be detrimental to the end result as to what hits your ears, instead of a perceived improvement.
    Happy listening either way. ;)
  • HB27
    HB27 Posts: 1,518
    Every time I change the tone controls I burn my fingers.
  • bluecomet
    bluecomet Posts: 1,118
    In one of my systems I mess around with I used a passive pre-amp from Yamaha the MVS-1 combined with a MX-630 amp. The amp has volume output controls. It is a very clean sound when you cut out all tone controls. On the other hand I have a SAE preamp and parametric equalizer, I find it interesting to modify the sound to your particular taste, EQ's and tonal controls do not mesh well with SDA speakers. Old monitor speakers on the other hand, especially the M10's did tend to benifit from the parametric EQ. Some gear just sound right together. It is a process to find the right combination.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • Conradicles
    Nice man nice.:cool:
    treitz3 wrote: »
  • AudioFilet
    AudioFilet Posts: 235
    If you use tone controls, does it make you a bad person??
    2 Channel rig:
    LSi9"s (modified xover's) & HSU Sub
    Harman Kardon HK 990 Amp
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
    HK AVR-745 & Polk Monitor Series
    F1nut Posts: 52,406
    joeparaski wrote: »
    Joe
    You should remove those EQ's from your system. It will take some adjustment of your part getting use to what the music is suppose to sound like, but once you do, you'll never go back.
  • headrott
    headrott Posts: 5,496
    treitz3 wrote: »
    Agree with the above 100%.
