Dead PSW202
acasella
acasella Posts: 2
I believe my Powered Subwoofer has died. I had it connected through Line In port from Onkyo TX-SR600 Receiver. I'm getting no sound anymore. I've tried doing sound tests to no avail. What is the process for troubleshooting if there is a problem and if there is one, how do I get the sub replaced.
Thanks, Al
Post edited by acasella on
  • glemay
    glemay Posts: 574
    edited October 2003
    acasella,
    You should e-mail Polk's cutomer service and let them know. I think that is your best bet.
    Good luck!:)
    Main System:
    Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
    Second System:
    Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
  • acasella
    acasella Posts: 2
    edited October 2003
    Thanks for the reply.
  • fireshoes
    fireshoes Posts: 3,167
    edited October 2003
    As Ken S. would say, connect the audio outputs of your dvd or cd player directly to the audio inputs on the subwoofer. Turn the volume down on the subwoofer and begin playing a music cd. Slowly turn up the volume on the subwoofer and see if it is playing okay. You should have strong clean bass. If not, call polk customer service or email Ken.
  • glemay
    glemay Posts: 574
    edited October 2003
    My damn PSW202 just started to make a really bad clipping noise and it barely moving!!!!:mad: I'm going back to Future Shop:mad:
    Main System:
    Second System:
  • glemay
    glemay Posts: 574
    edited October 2003
    pardon me it is making a noise that sounds like really high distortion. Wait I can't describe it but it not suppose to be there!:mad:
    Main System:
    Second System:
  • glemay
    glemay Posts: 574
    edited October 2003
    got it! It sounds like static, that's the word I was looking for!
    Main System:
    Second System:
    VR3 Posts: 29,700
    edited October 2003
    Take your fingers, press evenly around the dust cap, slightly in, if you hear rubbing you blew the voice coil. If not, then I don't know. But it sounds blown.
  • glemay
    glemay Posts: 574
    edited October 2003
    too late. It's already in the box. I'm going to future shop tonight. Guess it was a good idea a got the 9 year extended warrenty. They should fix it free of charge.
    Main System:
    Second System:
