Questions on CV Joints and Suspension
If you don't replace the hub, I would consider replacing the wheel studs. Should be cheap & fairly easy to pound the old ones out.
-Dave -
Audiobliss -
When you get the control arm fixed, lift up the car and grab the tire from the top and bottom and try to wiggle it as if you were pushing one end in and the other out. If it moves, that could indicate the ball joint is bad. If not, then it should be good.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Serendipity wrote: »Just another note... what year is your Mazda3? In the picture it looks like a 2005 or so but I'm not sure.
If it is indeed a 5 year old with say, 60-80k miles, you should replace the wheel bearing anyways for safety. I did at 72k and the mechanic said it's a good idea to do this so I went with it.
Wow Serendipity...It seems that you are an easy sell. Replacing bearings at 72K just because *"it`s a good idea" is NOT a good idea. I would never ever suggest that a customer replace the bearings if the bearings are ok, regardless of mileage. A timing belt yes...bearing?... No Way!
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
joeparaski wrote: »Wow Serendipity...It seems that you are an easy sell. Replacing bearings at 72K just because *"it`s a good idea" is NOT a good idea. I would never ever suggest that a customer replace the bearings if the bearings are ok, regardless of mileage. A timing belt yes...bearing?... No Way!
Joe
Well, you've gotta keep in mind that NYC roads are lousy... especially in Brooklyn where potholes are more like sink holes. I had a leaking strut at around the same time too, so it's definitely due to road conditions.polkaudio RT35 Bookshelves
I visit NYC every year, and the roads are the same here in Montreal. The thing is, even a new bearing can crap out in a very short time. It's one of those "replace when necessary" components. When the bearing is giving out there are signs, particularly, noise from the wheel. It's not like the wheel is about to fall off and there is no danger involved.
Thanks for all the additional comments!
My pads and rotors are actually all good; they've recently been addressed.
I'll check into the wheel studs.
Serendipity - Thanks for the tip on how to check the ball joint!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
audiobliss wrote: »Thanks for all the additional comments!
Keep in mind that if there's play when you do that "test," there may be more issues at hand than just the ball joint. Tie rods are brought to mind, as well as disintegrated bushings. Though if you're going to replace the control arm, bushings shouldn't be an issue.
My ball joints are fine on the MX6, but the wheel will jiggle back and forth a little bit. Needs the outer tie rods replaced.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Keep in mind that if there's play when you do that "test," there may be more issues at hand than just the ball joint. Tie rods are brought to mind, as well as disintegrated bushings. Though if you're going to replace the control arm, bushings shouldn't be an issue.
+1
If he's going to take it somewhere and get it diagnosed, then they should be able to tell him what's wrong.polkaudio RT35 Bookshelves
Thanks so much, guys! There's currently about 5 or 6 inches of snow outside, and it's supposed to stay there for a few days, so it'll be a while before I make any more progress on it. But I suppose I don't actually have to (or even can) do anything to it before I get a control arm and a new wheel. I'll be searching around for both of those.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
