LSi15s
Have a comparison of the specifications of the two speakers (-LSi15- the original and DB840).
Thank you. -
the LSi15's and 9's are speakers I will die with.....I've heard way pricier speakers that I like less. I had SDA 2B's and 1B's.....I like the LSi's better. just my .02 and obviously that si subjective.
LSi's will obviously have a strong presence at this years Polkfest.
I have yet to hear a polk speaker sound better then the Lsi 15's .Dan
Get your ears on any SDA-1c's or above... Don't get me wrong on The LSi15's as they are a great speaker, but the soundstage, imaging and presence the SDA's provide is far better IMHO than anything Polk has done since.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Thank you.
I wasn't able to find anything on the original woofer of the LSi. Any specs I found were for the speaker as a whole. Both are 4 ohm and both seem to measure down to around 30Hz.nooshinjohn wrote: »Get your ears on any SDA-1c's or above... Don't get me wrong on The LSi15's as they are a great speaker, but the soundstage, imaging and presence the SDA's provide is far better IMHO than anything Polk has done since.
I can't decide if I agree or not. I don't know if I'd call the 1C's better, but definitely different. One of these days I'm going to A/B mine in the same room on the same equipment and see if I can make a final decision. I do agree that the soundstage, imaging, and presence of the 1C is better, but there's just something about the 15's that are better than the 1C's. Maybe it's the overall clarity.Things work out best for those who make the best of the way things work out.-John Wooden -
^^^ clarity perhaps. It was not until I played my 15's with the 600x2 that they came to life. I agree they are a very good speaker, but it takes a pretty STRONG amp to get them to open up enough for all the detail to emerge from them.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »...it takes a pretty STRONG amp to get them to open up enough for all the detail to emerge from them.
Definitely agree with this. Unless of course my amp is not considered strong. In that case, I really need to hear them correctly powered because I think mine sound great;).Things work out best for those who make the best of the way things work out.-John Wooden -
nooshinjohn wrote: »^^^ clarity perhaps. It was not until I played my 15's with the 600x2 that they came to life. I agree they are a very good speaker, but it takes a pretty STRONG amp to get them to open up enough for all the detail to emerge from them.
This was my biggest fear on buying these speakers... That I wouldn't be able to discern a move up in SQ because I didn't have enough amp power and I would have to scramble to find a more powerful used one that wouldn't break the bank. I was very relieved that I did hear a big difference. Thing is, they still need breaking in time and I don't even have them on floor spikes yet (ordered a pair from the link that PSOVLSK kindly provided and are due in today) so I'm still looking to get more improvements. I believe what people say in regards to power, but I also believe what they say in regards to quality as being more important, and now that I feel I have some breathing room to wait for a good used quality amp that I can afford, I feel so much better about buying these speakers. I have good imaging (Tori Amos is singing to me right in front of me with the musicians spread out around her) and good detail, but that and the bass will get even better when I get them off the floor and put break in some break in time this weekend. In a year, I will get an upgrade as far as an amp when I have the money saved up and I probably will do the woofer upgrade as described here as well. Right now, I'm very happy with these speakers and feel each upgrade after this will be more of a pleasant surprise and not an urgent need.Pioneer vsx-9130txh-k
Anthem Pre2L SE
Marantz cd5003
Proceed amp 3
Sherwood Newcastle A-965
Signal ll IC's
Polk lsi-15s
Polk lsic
PSW505
Polk Monitor 30 surrounds side and back
PS3 with modified 500 gig hd
Samsung ln52a650 -
Exactly. Well said!!Things work out best for those who make the best of the way things work out.-John Wooden -
Same happened to me, I found no information.
For that reason I prefer the original that is scientifically proven by the boys PolkAudio -
That's what's so cool about this hobby. You can have great sound that you're totally happy with and also know that even better sound is just a component or cable swap away!SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub -
How can you prefer one over the other if you have not tried them both?
Also Polk specs say the 15's play down much further than they really do.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
TouchOfEvil wrote: »How can you prefer one over the other if you have not tried them both?
Very easy, PolkAudio is the manufacturer. They designed the LSi series after years of experience. That's more than enough argument. -
Oh lawd lol. I guess you think upgrading the crossover is a waste of time as well and you prefer the stocks because thats what Polk Audio put in there right?
Well good for you, you just saved some money.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
TouchOfEvil wrote: »Oh lawd lol. I guess you think upgrading the crossover is a waste of time as well and you prefer the stocks because thats what Polk Audio put in there right?
Upgrading the crossover? YES, only if the manufacturer does. Why experiment? I am no audio engineer. That is the work of experts.
01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
02) SUNFIRE Grand Signature - Bob Carver's
03) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
04) OPPO BDP-83 Blu-ray Disc Player w/SACD & DVD-Audio / DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
05) HITACHI P55T501. 55" HD1080 Plasma HDTV
06) POLKAUDIO LSiC (Center speaker)
07) POLKAUDIO LSi15 LEFT (Front speaker)
08) POLKAUDIO LSi15 RIGHT (Front speaker)
09) POLKAUDIO LSif/x LEFT (Surround speaker)
10) POLKAUDIO LSif/x RIGHT (Surround speaker)
11) VELODYNE OPTIMUN SERIES 12" (High Output Digital EQ SubWoofer 2400W/1200WRMS)
Stereo:
DENON AVR-4810CI / Quad ESL / Mbl 8011A M.
