Need Center Channel Speaker Wall Mount Suggestion
macaw
macaw Posts: 2
I'd like to hang the center channel just above the TV on the wall. I don't want any mechanism that attaches it to the TV - just to the wall.
I'd also like to have the speaker just hanging there without any mount or brackets visible. Any suggestions?
Post edited by macaw on
  • Face
    Face Posts: 14,340
    edited September 2009
    Which center do you have?
    Is your TV wall mounted?
    Nice screen name and welcome to Club Polk!
  • macaw
    macaw Posts: 2
    Hi Face,
    The TV is not wall mounted - it's on a stand. The speaker says "Model: CSM Black" on the back.
    -Macaw
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    I made a shelf/stand for mine that i bolted to my TV stand, completely invisible from the front. And it cost me less than $20 to boot :)
    I will make a better version with a better angle in the future (i need access to a table/skill/mitre saw) but for now it work's well :o
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • Face
    Face Posts: 14,340
    You can use a small wall mounted tv stand for your center.
    http://www.standsandmounts.com/index.asp?PageAction=VIEWCATS&Category=230
  • swmich42
    swmich42 Posts: 7
    edited February 2010
    Looking to mount Center channel below TV. (TV is wall mounted) Would like to know if anyone has incorporated minimal mounting hardware, which the speaker attaches to, or sits on.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    As far as I know the CS1 is not wall mountable, but I could be wrong. I have it's big brother, the CS2 and I know it is not. Try looking into a shelf or some sort of stand to put it on, those will probably be your best options. Welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
