Need Center Channel Speaker Wall Mount Suggestion
macaw
I'd like to hang the center channel just above the TV on the wall. I don't want any mechanism that attaches it to the TV - just to the wall.
I'd also like to have the speaker just hanging there without any mount or brackets visible. Any suggestions?
Post edited by macaw on
Which center do you have?
Is your TV wall mounted?
Nice screen name and welcome to Club Polk!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Hi Face,
The TV is not wall mounted - it's on a stand. The speaker says "Model: CSM Black" on the back.
-Macaw -
I made a shelf/stand for mine that i bolted to my TV stand, completely invisible from the front. And it cost me less than $20 to boot
I will make a better version with a better angle in the future (i need access to a table/skill/mitre saw) but for now it work's well
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
You can use a small wall mounted tv stand for your center.
http://www.standsandmounts.com/index.asp?PageAction=VIEWCATS&Category=230"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Looking to mount Center channel below TV. (TV is wall mounted) Would like to know if anyone has incorporated minimal mounting hardware, which the speaker attaches to, or sits on.
As far as I know the CS1 is not wall mountable, but I could be wrong. I have it's big brother, the CS2 and I know it is not. Try looking into a shelf or some sort of stand to put it on, those will probably be your best options. Welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
