SVS cylinder or box?
Hello,
I have a set of Polk RT speakers (RTi70, CSi40, RT35). I have read in this forum and others that the SVS subwoofers match well with Polk speakers. I was thinking of getting the 25-31 PC+, which is a cylindrical sub. However, I have noticed that lately on this forum most people have been talking about and recommending the SVS box subs. Why is that? Is there a difference in sound or is it just an aesthetics and WAF issue?
Thanks,
Jim R.
Thanks,
Jim R.
Post edited by jim_r on
Originally posted by jim_r
Hello,
Thanks,
Jim R.
No sound difference, just aesthetics and WAF, really.
The PB1-ISD is identical in sound to the 25-31 PCi and/or 20-39 PCi.
The PB1-Plus is identical in sound to a 25-31 PC+ and/or 20-39PC+
But dual co-located 25-31 PC+ will outgun a PB2+ below about 28 Hz due to their larger combined port area. So dual cylinders still outperform the PB2 series, but not by much."What we do in life echoes in eternity"
SVS -
I've checked out all the specs and it seems like the PB2 line is just a better value than the two cylinder subs you would need to match it's performance. If you don't need as much sub as the PB2 (like in a smaller room) then get a single cylinder sub. If you are looking into double cylinder subs though, I think a PB2 makes more sense from a value standpoint.
You are correct; the PB2-ISD and the PB2-Plus are pretty amazing values when you consider the price of dual cylinders.
Where the disparity between duals and a PB2 becomes the most noticeable is below about 25 Hz. That's where air flow and port area becomes the most critical.
Nevertheless, Tom V claims a $899 PB2-ISD tuned to 20 Hz (that's with a port plugged) will still outgun a $825 20-39PC+ above 20 Hz by 2-3 dB. Tune it to 25 Hz (all ports open) and it walks away by 4-5 dB above 25 Hz. Very impressive.
Still, the 20-39 really shines when trolling and the subjective bass quality of the 20-39 in the 17-20 Hz region is just outstanding.
I find the subjective sound quality of the PB2 to be the best with all ports open and it will not troll as deep as the 20-39 in this tune.
The PB2-Plus and PB2-Ultra are simply more of the same. Add (above the ISD) another 3 dB for the Plus and another 2 dB for the Ultra.
Unless you want 120 dB at the seat, the PB2-ISD is a screaming deal for $900. It gives away very little to the PB2-Plus in real world performance.
Doc"What we do in life echoes in eternity"
SVS -
Thanks for the information guys! I'm not really a big fan of subwoofers. The only reason that I am getting one is to protect my RTi70's, since my Rotel will send them the .1 LFE if I don't have a sub. So, I think I am going to stick with the 25-31 PC+. The equivalent of two subs in the PB2 would be overkill for me and the PB2 is a bit heavy. I would also like something a little better than one of the PCi subs. So the PC+ should be a good choice for me. Hope to work it into next month's budget. Thanks again!
......I think I am going to stick with the 25-31 PC+.
That opinion will change very quickly after you get the SVS.
If you don't play super SUPER loud, I recommend the 20-39PC+ over the 25-31PC+ as the best combination of output and extension."What we do in life echoes in eternity"
SVS -
Dr. Spec,
How do my dual 20-39cs+ with a samson s1000 compare with the newer models? Thanks!!! -
Ok, I'm sick of it, what in the hell does WAF mean? Wife and family? Clue me in please.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
"If you could put speakers in a needle, I'd never see him again..." - My Girlfriend -
I am not sure but I always thought it was Wife Anger FactorFront
Polk RT800i (BI-wired)
Rear
Polk RT600i
Center
Polk CS400i (BI-wired)
Sub
SVS 25-31PCi (22Hz tuning port)... it's SubHuman
Receiver
YAMAHA RX-V1400
TV
Mitsubishi WT-46807 HDTV
HD receiver
T i V o HR10-250 -
wife approval factorMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
approval / anger same thing
Front
Rear
Polk RT600i
Center
Sub
Receiver
YAMAHA RX-V1400
TV
HD receiver
T i V o HR10-250 -
If your wife doesn't approve, get a new one. If someone doesn't get the idea of home theater then they shouldn't be able constrict it. If your wife thinks a sub is big and ugly, remind her how much bigger it is than her ****.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
I take it your not married..
My wife loves the whole HT thing.. guess im lucky, however she didnt care for the cylinder SVS, so we got the box
what ever she says right? LOL MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
If I were married, they would understand the concept of home theater. If she can't comprehend my outreaches of interest and passion, the she isn't what I'm looking for.
My girlfriend really likes the cylinder SVS's. They go along with the aesthetic appeal in systems for both of us. I hate hearing all the "well my wife won't let my me put my speakers up unless I have beanie babies on top"
My girlfriend calls them "goofy ****"...heh. I'm just lucky.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
theres a good way to get yourself sleeping on the couch
I truly don't understand 'happy marraiges' where it's a give and take situation in personal passions. "I won't do this part of what I love if you won't do this part of what you love." 36 dogs, I get..polka dots on the house, yes..serial killing as a hobby, I understand.. It's a **** theater..you're SUPPOSED to have equipment in order for it to work properly. No matter the size.
Relax.
Take off the flowery ninja costume and step away from the wallpaper. Put down the beanie babies and breathe.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
im only 16...so i dont have to worry about what you are talking about, my HT is in my bedroom.
too bad my girlfriend doesnt like loud music or loud movies, oh well i dont live with her haahaa -
My girlfriend doesn't like loud, but she does like clear. Polk helps me there.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
I am laughing my **** off. I like the part about the flowery Ninja costume and the wallpaper. My opinion is if your woman can't deal with it, then kick her out and just pay for a hot **** escort when you want a woman. I mean either way you gotta pay. At least you can tell the escort to leave when you are tired of dealing with all her feminine side effects. You know, when they show you those commercials on TV about all the great things a new prescription drug can do for you, then they rattle off a whole list of side effects. Women are the same way. "Your woman will make you feel great and you will not be depressed anymore. Common side effects include constant nagging, bitching, complaining, having to hide your new polk speakers, mood swings, and you might have to choose the box sub instead of the cylinder sub."
I feel sorry for men who have to ask permission to buy something that they want. -
Check out my post in speakers "wife gone." She will **** a little about the price at first but after she hears the sound . She will get over it ! I believe she is a closet audiophyle. She wants the HT but she thinks we can't afford it so she let's me be the bad guy. I can do that."It doesn't get any more serious than a Rhinocerus about to charge your ****."
Originally posted by gplracer
Dr. Spec,
If they are co-located, they still beat all newcomers except the B4+, dual Ultra's, dual SS', and possibly the PB2-Ultra."What we do in life echoes in eternity"
SVS -
Waaaaaaaaaa!
how true is that?PolkFest 2012, who's going>?
I just got a SVS 20-39PCi. the sucker is bigger than I thougth it would be. my findings so far.. only in how it looks are that it's big and tougher to blend into the room. The 39" tall 2039PCi is not able to hide as a coffee or end table like my other smaller sub was able to.
The nice thing about the cylinder subs is that they are pretty lightweight. I can easily lift and move it around the room without even breaking a sweat or my lower back. As some of you might know... large box subs can get pretty heavy.
The cylinder subs from SVS are just as good as the box subs from SVS. And yes they blend extremely well with i70's/800i's. Mmmmmm!PolkFest 2012, who's going>?
I could be wrong, But i think this is directed somewhat or totally towards me, Liquid... I really dont appreciate your sarcasm! i can have anything i want.. But in a marriage its give and take and although the cylinder would have been " OK" Myself and my wife decided on the box.. I thought the tube looked like **** actually.. Not sound wise but looks.. I feel for your future wife with an attitude like yours.. And being um the only one on the board that has posted pictures of my gear and speakers with beanie babies on them, again.. im sure your comments were towards me.. I say she lets me have what i want if she has her beanies on the stuff just to shut people up Like Russman and others who make dumb **** comments about Dolls and beanies being in my pics.. don't like it don't **** look.. I love my wife and she can have what ever she wants where she wants.. and i have my gear.. Unfortunatly we have a HT/living room/family room all in the same place.. so it has to "work" for everyone.. you seem to get uptight and make "dumb" comments to people and it just doesnt always seem appropriate.. But i guess your "lucky" to act like this and no one say anything about it!!
Ok i know this will turn into a HOS candidate, But eff it i'm tired of the stupid comments..
For the record, Everyone shut up about the beanie and dolls.. Its alittle played out.. I know i know it wasnt meant towards me :rolleyes: what ever!!!!!!!!MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
How did MY name end up in this post by the 23rd reply?
Faster, I think it was a *general* statement, not directed towards you.
****' beanie babies....pfffft - not on my shift. Goofy ****, THAT is funny - I'll raise a glass to the goofy **** tonight, and thank the lord I ain't married to one!
Cheers,
The Anti-BeanieCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
I collect action figures and antique toys.
Hey we all do what we do, to each his own. If you want to paint flowers on the grill covers that is your choice. Everyone has their own style and you can always find someone that doesn't like something.
Don't let it get to you and don't knock what someone has, put simply be polite.Front
Rear
Polk RT600i
Center
Sub
Receiver
YAMAHA RX-V1400
TV
HD receiver
T i V o HR10-250 -
/derail/
Grey, I've got some vintage Matchox 50's-70's (reg wheel/ superfast/ king size) I'm looking to un-**** on the cheap. Interested? - pm or email me.
/end derail/Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Cheers,
The Anti-Beanie
Russman, no offense meant towards you.. it was a point i was trying to make.
here we go again, with "it was a general statment" No it wasnt.. he got mad because i said, "you must not be married" It wasnt meant to down him, hence the smiley.. everyone knows we have beanies on my speakers.. So it wasnt generally speaking.. and to make comments about goofy ****, he's just being a dick..
But im not gonna ruin my night becuase of him.. he just doesnt have a clue, and what woman does he think he'll marry that is only all into his audio and if not she aint worth it? Their is more then audio in life.. My family and wife come first.. But what ever..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Look guys! It's the Swiss Alps again!!
Lighten up man, I didn't mean it as a personal attack. Sorry you took it that way. I'm not mad about anything.
For reference, other women in the world try to frilly up manly things around the house. It WAS a general statement about frillification. Take it as you will. No harm intended.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Who cares if you have beenies on/behind/beside your speakers... at least you have the speakers...
Don
