What Subwoofer To Buy ????
russell55
russell55 Posts: 12
edited October 2003 in Speakers
I just recently joined the polk family with the purchase of a pair of Rti70's, a Csi40, and a pair of Fxi30's. I am unsettled on a subwoofer at this time. I have only looked at the pw404 and the Velodyne CHT-10. Circuit City is pushing the velodyne CHT-10. My budget is around $400.00. I want to use is for both music and movies. Any sugestions????
PS: I am using a Radio Shack 10" 150 watt special at this time.
Post edited by russell55 on
  • andrewe77
    andrewe77 Posts: 17
    edited October 2003
    Save up for an SVS.
  • gplracer
    gplracer Posts: 36
    edited October 2003
    SVS - The velodyne is real boomy. I had one and took it back. The SVS is much better for music and has a ton more of low end bass.
  • russell55
    russell55 Posts: 12
    edited October 2003
    any particular model ?
  • gplracer
    gplracer Posts: 36
    edited October 2003
    Well i have dual 20-39cs+ subs but you might want to go with the 20-39pc+. It is a good all round model and it comes with the amp built in.
  • russell55
    russell55 Posts: 12
    edited October 2003
    Thanks for the input, I found their web sight and I will do a little research.
    Dave
  • kberg
    kberg Posts: 974
    edited October 2003
    russell,
    Your setup is real close to mine. I highly recommend the SVS 20-39 PC+. Doc recommended this one for me; it blends in beautifully and brings everything together. However, your room size/configuration, acoustics, budget and other factors play an important role in deciding what sub to purchase. If you're considering an SVS, post your specifics here - I'm certain Doc and others would provide specific and useful information/recommendations, and/or email Tom or Ron at SVS and give them all of the above info plus anything else that may ask you about - either one of them will also provide you with the best sub for your situation/budget - guaranteed!
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited October 2003
    Also look at the Adire Rava, Dayton Titanic, VMPS's and HSU's offerings. SVS is a great choice also, but you do have some real good options in that price point.
    Cheers,
    Russ
