Does using preouts cancel signal?
Red777
Red777 Posts: 19
Just wondering if using the preout cancels the receivers amp channel for that speaker? Could I still use the available power to bi-amp?
55 Samsung 7100
Pioneer 1017vsx
Pioneer 51fd BluRay
Sony TAN9000es Amp.
Polk RTI8
Polk CSI3
Polk FXI6
Polk RTI4
Velodyne dps10
xbox 360
AR xsight remote
Post edited by Red777 on
  • Montoya
    Montoya Posts: 506
    edited January 2010
    Not a good idea it would work but the level gain could be different causing many audible problems.
  • tcrossma
    tcrossma Posts: 1,301
    edited January 2010
    Red777 wrote: »
    It depends on the AVR, but usually Yes. It probably won't make any audible difference, but you could try it.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Red777
    Red777 Posts: 19
    edited January 2010
    So even if I wanted to just run the fronts in another room off the AVR's amp-they are not functioning anymore due to using the preouts? But give it a shot anyhow.........
    55 Samsung 7100
    Pioneer 1017vsx
    Pioneer 51fd BluRay
    Sony TAN9000es Amp.
    Polk RTI8
    Polk CSI3
    Polk FXI6
    Polk RTI4
    Velodyne dps10
    xbox 360
    AR xsight remote
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2010
    I have not tried to see if my AVR amp is still getting a signal with the preouts being used. I can tell you it gets as hot just using preouts as it did when using the amp.
  • Montoya
    Montoya Posts: 506
    edited January 2010
    I know with my pioneer you have to turn off the amp section or both will run.
  • Red777
    Red777 Posts: 19
    edited January 2010
    The AVR (poineer) is very warm, as usual. I did not see a setting in the menu to turn off the amps.
    55 Samsung 7100
    Pioneer 1017vsx
    Pioneer 51fd BluRay
    Sony TAN9000es Amp.
    Polk RTI8
    Polk CSI3
    Polk FXI6
    Polk RTI4
    Velodyne dps10
    xbox 360
    AR xsight remote
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2010
    Red777 wrote: »
    Depends on the AVR - the Yamaha manual explicitly recommends NOT running pre-outs and speaker connections at the same time.
    Not sure if the universe implodes or not if I were to try... :D
    ymmv...
  • thuffman03
    thuffman03 Posts: 1,325
    edited January 2010
    Do not bi amp using your AVR and any other amp. IMO that is a waste of time. Get an amp that will power the speakers you have and use the AVR as a pre.
    Most AVR's amps will not match the same output as a good seperate amp.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Red777
    Red777 Posts: 19
    edited January 2010
    My manual lists nothing about it. The AVR is as warm as it was when i was running the speakers off of it. I have the extra set of wires sitting there, and an unused ampsection from the AVR. At the very least could i power another set of mains/bookshelves in another room? Hate knowing there is unused 'power'-especially with the heat ouput reminding me its drawing it down.
    55 Samsung 7100
    Pioneer 1017vsx
    Pioneer 51fd BluRay
    Sony TAN9000es Amp.
    Polk RTI8
    Polk CSI3
    Polk FXI6
    Polk RTI4
    Velodyne dps10
    xbox 360
    AR xsight remote
    edited January 2010
    Normally,thats a no. When useing the preout for that channel,usually you can't use the receivers amp section for that particular channel. You might send that receiver into protect or something worse. Not worth trying to bi-amp with a receiver anyway,better choice is to get a different amp.
  • Red777
    Red777 Posts: 19
    edited February 2010
    So, I could possibly hurt something by trying/doing. Thanks. Although I wish PIONEER would do something about all this heat created by an AVR thats not even using the amp section (except for the rear backs), the fronts, center and rear surrounds are coming off the sony amp. Oh well, know of one that allows usage when using preouts or doesn't draw down the juice when doing so for nothing.
    55 Samsung 7100
    Pioneer 1017vsx
    Pioneer 51fd BluRay
    Sony TAN9000es Amp.
    Polk RTI8
    Polk CSI3
    Polk FXI6
    Polk RTI4
    Velodyne dps10
    xbox 360
    AR xsight remote
