aussie amplifiers kits!
lanchile
Hello guys. I just finished my diy amplifier using nxv200 from Aussie amplifiers.
I had many good commercial amps like Adcom, Acurus, Marantz, Portal panache, Bryston, Luxman etc, and I also have build many diy amps.But I have never heard a beautiful sound as these amp kits. they are top notch. and whom ever knows a little how to read voltages and some solder work will be just fine to build these fantastic diy amps. just read reviews. you will not regret it. I am just waiting for some input caps "Sonicap from Sonicraft".
Trust me when I say this diy amp can kick some a$$ even all those mentioned above. Here are some pictures.;)
Make it simple...Make it better!
Post edited by lanchile on
Ummm . . . I like amps, but unless you start sounding less like a salesman, I bet you'll be reported here quickly.
I am using with my Polk speakers the small tanks RTi A1.Make it simple...Make it better!
SolidSqual wrote: »Ummm . . . I like amps, but unless you start sounding less like a salesman, I bet you'll be reported here quickly.
I just wanted to "share" some pictures of my new diy amp with everyone . do not be so hard buddy! Maybe some people are looking to jump to diy amps.Make it simple...Make it better! -
Cool! How long did it take to build?
SolidSqual wrote: »Cool! How long did it take to build?
it took me like two weeks, I had to wait for parts from 3 different companies.the longest was for the transformer(one week).Make it simple...Make it better! -
Cool. And why the name? Do you fly? Or are you Chilean?_________________________________________________
You got that right! I am from Chile. so that makes me a Chilean hehehehehe;)Make it simple...Make it better! -
I have the same RS knob. How much are we talking here for the kit and parts?
Specs?
Can it make the Black Eyed Peas sound better?I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
Pucha cay.....I was born in Santiago. Left when I was still very young.
I miss locos, huesillos, chicha, porotos granados y cazuela
Wena.........Un abrazo compatriota!!! te faltaron las empanadas y el pan amazado jajajajaja Viva Chile!!!Make it simple...Make it better! -
Ahhh..las ayuyas.
Carry on now.
Looks like the typical flavor "LM" series chip-amp. I owned one of Peter's for awhile with Caddock resistors, and Black Gate caps and it was impressive initially, but at the end of the day it was too analytical and was too disconnected from the music, it seemed each part of the music was playing independently and never seemed to integrate together into a singular cohesive output. Very sterile sounding, not at all "real"
Nice workmanship...............glad you are enjoying it.
Well. this is not a chipamp, I had one LM3875 from Peter Daniel too. These are diy amps kit from Aussie amplifiers these are the nxv200. they sound awesome!.The bridge rectifier is from Peter Daniel using mur860 and some smooth caps on the bottom.Make it simple...Make it better! -
MillerLiteScott wrote: »I have the same RS knob. How much are we talking here for the kit and parts?
Specs?
Well, lets see here. The boards are around $300 per pair (stereo), the transformer is $130, the mundorf caps are $100, The Sonicaps are $20, the potentiometer is $25 that is the total of $575 more or less! plus the rest like bridge rectifier, smooth caps,thermistors,cables,switch,chassis etc.But I used an old chassis from a Portal panache amp so I save some money there.I know with that kind of money I can get a new amp or an used one on eBay but,Trust me when I say I had so many amps including tube ones,But I always found something wrong with them, They never pleased me 100%. if anyone is for diy amps...look not farther!.The nxv200 amp kits can beat many good commercial amps even some Bryston amps!!! yeah you hear me right even some Bryston amps. How do I know this? Because I had a few Bryston too! and I did a test with some of my friends amps like Blue Circle, Bryston, Luxman, Adcom, and a $3000 amps that I do not remember the name but it was a monster.I do not say these diy amps are the best but,They definitely are worth to build one.;)
This is the potentiometer That I am using 10k.Make it simple...Make it better! -
If it could make the Black Eyed Peas sound better I would be truly impressed!
I want my boom, boom, boom to sound awesome!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Specifications
110 Watts RMS continuous sine wave into 8 Ω
180 Watts RMS continuous sine wave into 4 Ω
The HPA-nxV200 is 2 Ω Stable
Biased into Class A/B
Power Bandwidth 3.5hz to 600khz -3dB
Small Signal Bandwidth 3.5hz to 3.5mhz
Dampening Factor At 100hz 8Ω = 800
Dampening Factor At 1khz 8Ω = 650
Dampening Factor At 10khz 8Ω = 250
RCA Single ended Input impedance 33kΩ
Single Ended Input Gain = 30.6dB
Signal to Noise Ratio -120dB
THD+N - Typically 0.005%
Recommended Linear Voltage Supply +-50 volts DC
Operational Supply Voltage Range +-10v DC to +-60 volts DC
Printed Circuit Board Dimensions 50mm x 50mm
Ultra small form factor PCB
Designed as high performance Home Theatre multi channel amplifier
Or High End 2 Channel stereo amplifier
Unconditionally Stable into any load from 4 to 16 Ohms
Extra Heavy Duty three ounce copper printed circuit board
Ground plane Layer for very low noise.
Rugged high performance complementary Toshiba MOSFET Output Stage.Make it simple...Make it better! -
Looks nice but a bit spendy for me.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
MillerLiteScott wrote: »Looks nice but a bit spendy for me.
Well, you always have the choice to build a "gainclone" amp like LM3875 from Audiosector they sound good and they are not too pricey to build. just if you are in the diy staff.;)Make it simple...Make it better!
