What Subwoofer To Buy ????
I just recently joined the polk family with the purchase of a pair of Rti70's, a Csi40, and a pair of Fxi30's. I am unsettled on a subwoofer at this time. I have only looked at the pw404 and the Velodyne CHT-10. Circuit City is pushing the velodyne CHT-10. My budget is around $400.00. I want to use is for both music and movies. Any sugestions????
PS: I am using a Radio Shack 10" 150 watt special at this time.
Post edited by russell55 on
Save up for an SVS.
SVS - The velodyne is real boomy. I had one and took it back. The SVS is much better for music and has a ton more of low end bass.
any particular model ?
Well i have dual 20-39cs+ subs but you might want to go with the 20-39pc+. It is a good all round model and it comes with the amp built in.
Thanks for the input, I found their web sight and I will do a little research.
Dave -
russell,
Your setup is real close to mine. I highly recommend the SVS 20-39 PC+. Doc recommended this one for me; it blends in beautifully and brings everything together. However, your room size/configuration, acoustics, budget and other factors play an important role in deciding what sub to purchase. If you're considering an SVS, post your specifics here - I'm certain Doc and others would provide specific and useful information/recommendations, and/or email Tom or Ron at SVS and give them all of the above info plus anything else that may ask you about - either one of them will also provide you with the best sub for your situation/budget - guaranteed!Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
Also look at the Adire Rava, Dayton Titanic, VMPS's and HSU's offerings. SVS is a great choice also, but you do have some real good options in that price point.
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
