How do I tell if a Subwoofer is In Phase?
I purchased an Eosone 10" Subwoofer driver from a liquidator to install in my own enclosure. The problem is that the woofer's contacts aren't marked in any way, so I don't know which is positive or negative. There is a skinny connector and a fatter connector.
I felt the woofer while playing a kick drum to it, to make sure that the woofer was extending on the kick, but it was hard to tell which one was extending, and I gave it my best guess.
I would appreciate your advice.
Post edited by DaveClayton on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2010
    Take a c or d battery and hook it up to the terminals. The woofer will push out when the positive of the battery is on the positive speaker terminal.
    Ben
  • DaveClayton
    DaveClayton Posts: 5
    edited February 2010
    Thanks for the advice! Will this damage the woofer in any way?
  • dorokusai
    dorokusai Posts: 25,576
    Nope.
  • halo71
    halo71 Posts: 4,630
    ben62670 wrote: »
    Damn, learn something new everyday!
    Also, I always thought the fatter terminal was positive.
    --Gary--
  • mantis
    mantis Posts: 17,357
    here is the rule of thumb when placing a sub into a room.
    Front wall should be phase 0
    Side wall should be Phase 90
    Rear wall should be Phase 180.
    Basically you want to have your Sub "IN PHASE" with the other speakers meaning timing or stop and go the same way at the same time.
    Dan
  • mufsoman
    mufsoman Posts: 636
    Mantis, does a front corner place fall under the 0 degree setting? When I slowly change the phase setting from 0 to 180, I hear no difference in the base sound. Should I? If I should, then what does it mean when I don't??
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • mantis
    mufsoman wrote: »
    Front corner should be 0 phase setting. This means the driver is moving the same time as your mains and center channel. Phase is not a sound it's a timing.
    Dan
  • cpr0209
    cpr0209 Posts: 1
  • dorokusai
    fail.
  • DaveClayton
    Thanks for the discussion and advice.
