Doc, I'm looking for a new sub.
glemay
Doc,
Currently I have a Sound Dynamics THS 3000 subwoofer. It is a 12 inch downfiring sub with a 150 watt mosfet amp. I am not really satisfied with it. I have it in the corner and tried other places but still don't like the sound, it sounds boomy and unaccurate.
I was looking at spending around 750$ canadian at the most. I am looking at the Paradigm PDR-12, I think it is in the price range. What do you think? Is it better than the Velodyne CHT-12? What about the bigger Paradigm subs?
Is there anything anyone else can suggest?
Jerry
Jerry
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Second System:
Post edited by glemay on
I am also in Canada and have Paradigm speakers. I have heard the pdr12 and pw2200(1000cdn). They are both good but you can do better with DIY. I suspect a SVS pci or pb1 isd will also be around that price range (900-1000cdn shipped) and although I haven't heard one, I suspect they will perform better than paradigm.Graham
gatemplin,
what do you think about the Paradigm PS series? I don't know how they price out though?
JerryMain System:
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a -
Niether do I, they look great and the specs are pretty good. I havent heard them though. If you want to know the prices check out the audio ideas guide. They list retail , take about 10% of that off.Graham
"Rava" powered subwoofer $399 US
A very good quality and acurate sub with 250w RMS amp
http://www.adireaudio.com/home_audio/loudspeakers/exact_series/rava.htm
2-Channel Audio
Onkyo ... A-9050 . . .Integrated Amp. (Power Amp Section not Used)
Onkyo ... M-282 . ... Power Amps .(Pair)
Onkyo ... C-7030 . _.CD Player
Polk . . *. RTi A7 - ....Front Speakers
Polk . . *. RTi A3 - ....Rear Speakers -
Without a doubt, Paradigm is the best deal going if you live in Canada and are shopping for a sub. The 2200 and the Servo-15 are excellent.
If you want to import from the US, SVS should be on your short list.
Kyle over at Acoustic Visions is a Adire dealer and you can look several of his sub packages as good alternatives.
Velodyne makes very good subwoofers and are recommended; the CHT series is their entry level sub but is still very decent."What we do in life echoes in eternity"
SVS -
Dr. Spec ....
You didn't mention the Rava. Lots of very positive revues.
That SVS is a sweetheart, but I thought I would show him the Rava since he appeared to be somewhat price drivin.
_________________________________
My bad ... You stated "Acoustic Visions is a Adire dealer"
Jerry ... Adire Audio manufactures the Rava.
2-Channel Audio
does anyone know the price of the paradigm PS-1200?Main System:
Second System:
I like the ported Dharman for HT and more depth and SPL. But the Rava can't be beat for music.
http://www.acoustic-visions.com/~acoustic/products/subwoofers/pre_finished/"What we do in life echoes in eternity"
SVS -
doc,
i need a sub that is good at both music and htMain System:
Second System:
If you're looking for a sub which is good for both music and movies then look for Velodyne CHT-10. You can't go wrong with Velodyne subs.
http://www.hometheatermag.com/subwoofers/177/Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player) -
hamzahsh,
how do you think that would compare to the sound dynamics ths 3000 sub i got right now? it is a 12 inch down firing sub with a 150 watt mosfet amp. and with that i still am not satisfied. it isnt as accurate as i would like it to be.Main System:
Second System:
glemay,
I'm not sure about your sub but one thing I've noticed that it is downfiring and it could be the problem or not. My Velodyne CHT-15 which is a forward firing and it is in the front next to my TV and slightly on the angle of about 60 degrees towards my seating. Velodyne CHT-15 has 750 watts, 300 RMS of pure gut-wrenching power.
I watch movies and listen music and it never sounded boomy to me. The bass is tight and clean and loud enough to rattle things in other rooms of my condo. The bass is clean and natural.
Majority of the subs in the market is front-firing but quality of sub isn't judged by the facing of the driver. It doesn't really matter whether it is front or downward firing. There is no rule for placement either, you can place anywhere you want as long as it sounds good to you.
Try to position your sub, use receiver's crossover. Set it at 80hz and set all speakers to small. Keep the sub volume to no more than 50%. Before you buy another sub keep trying the one you've already.
Since you're from Ontario like myself from Toronto. Visit Future Shop and listen to Velodyne CHT-10 or CHT-12 CHT-15 is not available to listen but they sell it and they deliver it from warehouse.
I bought my Velo CHT-15 from Future Shop and love it so much that I've no words to describe. The CHT-15 is my dream sub and I always wanted it and now I've it. The sub sounds incredible for both music and movies. CHT-10 and CHT-12 both are amazing sub too.
There is another website called
http://www.audioreview.com and check out reviews for Velodyne subs which are CT-100, CT-120, CT-150, CHT-10, CHT-12 & CHT-15.
CHT is the new series CT is the old and CHT is better.
Good luck!Panasonic TH-50PX80U Plasma HDTV
NAD C272 (2-ch Amp)
hamzahsh
thanks for the link! it will be very handy!:DMain System:
Second System:
There is a guy over at HTF who owned dual CHT-15's. He now owns three SVS 25-31 PC+ with a fourth on the way (trying to do a B4+ the hard way I guess).
Anyway, he says one 25-31 PC+ equaled his dual CHT-15's down to about 30 Hz. Below 30 Hz, the single 25-31 played louder and ultimately went deeper than the dual CHTs.
The thread is pretty recent if anyone wants to search it. His name is "Steve nn"."What we do in life echoes in eternity"
SVS -
doc
thanks! that really makes svs look good! I want one but don't think my parents would allow me.:( Plus I don't have the money right now:(
Main System:
Second System:
glemay,
Go with whichever you like.
Good luck!
NAD C272 (2-ch Amp)
I got a Atlantic Technology T70 for $179 its a nice sub for the $$. But at your price range id look at the Velodyne,NHT,PSB,and the Rava. I would have to hear each of them to make a real decision as they are all good. If you want a good sun at a cheap price look at the CSW(cambridge sound works)Newton series also. check those out at ebay in hifi ebay store. Its a online clearing house for CSW stuff and you can get them about 1/2 street price there.
