Cool cable management
BuckeyeTim
Ok, here is a DIY tip that not only looks cool, but provides a function as well.
Spark Plug wire separators.
Rather than using twist-ties or zip-ties for "cable management"...Spark Plug wire seperaters. You can get them in several diameters depending on cable diameter. They also come in many colors and construction materials.
You use the 2 cable separator coming out of or going into components, connecting to 3 or 4 cable separators. You can overlap and combine them (even using different colors for easy I'd of various components). You end up with a very nice looking cable management system.
Not affiliated with the following, but try Summit Racing and you will see a vast variety.
Post edited by BuckeyeTim on
I love summit, drove down there many times when building my boat engine. sounds like a pretty cool idea, got any pics? I take pride in good cable management, very important and often overlooked part of this hobbypanasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
Summit RULES!!!!
BuckeyeTim wrote: »Ok, here is a DIY tip that not only looks cool, but provides a function as well.
Hey Buckeyetim....I'm curious about the name...Buckeye is a brand of powered parachute, do you own one?
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
I got buckeye cause he's in ohio?panasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
No, I don't have any pics at the moment, but will soon.
95% of my stuff had been in storage for about the last 10 yrs. We moved into a place that did not have room for anything. Two years ago we bought a place with some land out in the country, so I am just now breaking everything out.
At the moment, only a few componants fit into the "stand". Some stuff, including the amps are strung out across the floor. (Thank Zeuss for an understanding wife)
As soon as I get everything moved into the "under construction" listening room I'll be able to post a few pics.
Yep, you got it....Buckeye for Ohio. -
Thanks for the tip. Good idea
Simple yet particle I will try some on my system
Nice idea!
ATM i find that velcro is the best for me
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
