Cool cable management
BuckeyeTim
BuckeyeTim Posts: 490
edited January 2010 in DIY, Mods & Tweaks
Ok, here is a DIY tip that not only looks cool, but provides a function as well.
Spark Plug wire separators.
Rather than using twist-ties or zip-ties for "cable management"...Spark Plug wire seperaters. You can get them in several diameters depending on cable diameter. They also come in many colors and construction materials.
You use the 2 cable separator coming out of or going into components, connecting to 3 or 4 cable separators. You can overlap and combine them (even using different colors for easy I'd of various components). You end up with a very nice looking cable management system.
Not affiliated with the following, but try Summit Racing and you will see a vast variety.
Post edited by BuckeyeTim on
  • superjunior
    superjunior Posts: 1,632
    edited January 2010
    I love summit, drove down there many times when building my boat engine. sounds like a pretty cool idea, got any pics? I take pride in good cable management, very important and often overlooked part of this hobby
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
    Toolfan66 Posts: 18,364
    edited January 2010
    Summit RULES!!!!
  • zingo
    zingo Posts: 11,258
    edited January 2010
    That's good idea!
  • joeparaski
    joeparaski Posts: 1,865
    edited January 2010
    BuckeyeTim wrote: »
    Hey Buckeyetim....I'm curious about the name...Buckeye is a brand of powered parachute, do you own one?
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • superjunior
    edited January 2010
    I got buckeye cause he's in ohio?
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • BuckeyeTim
    edited January 2010
    No, I don't have any pics at the moment, but will soon.
    95% of my stuff had been in storage for about the last 10 yrs. We moved into a place that did not have room for anything. Two years ago we bought a place with some land out in the country, so I am just now breaking everything out.
    At the moment, only a few componants fit into the "stand". Some stuff, including the amps are strung out across the floor. (Thank Zeuss for an understanding wife)
    As soon as I get everything moved into the "under construction" listening room I'll be able to post a few pics.
    Yep, you got it....Buckeye for Ohio.
  • polkymond
    polkymond Posts: 11
    edited January 2010
    Thanks for the tip. Good idea :) Simple yet particle I will try some on my system :)
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited January 2010
    Nice idea! :D
    ATM i find that velcro is the best for me :o
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
