Towers All Around?
I recently purchased a pair of Monitor 60 refurbs from the Polk Direct Store on Ebay. They sound great and you couldn't tell that they are refurbs, not a scratch. Got the pair of Cherry for $175.
I'm thinking of using the 60's as my side speakers in a 5.1 and putting Monitor 70's up front with my 55" Sony HD. The room is about 15 X 25 and open ended on one end. I've got plenty of power with my Yammy AV Receiver. Is this overkill? Should I maybe just add some Monitor 40s for the sides?
Thanks.
Mark F.
Thanks.
Mark F.
Post edited by Force on
If you have the speakers already and the room, why not? The 40's would probably serve you just fine if you don't mind stands or using a bracket and wall mounting them. You know you'll have plenty of range with either selection. From everything I've read on here, surrounds aren't as important as the main 3 speakers in the front soundstage.Chris
5.1
Denon 890
Polk TSi300
Polk TSi100
Polk CS10
MTX SW2 Sub
2.0
Polk SDA-2A
NAD 7175PE -
After I upgraded my fronts I moved my 60's to surrounds, they sound good to me...
I've heard a few say that as well. But idealy you would want all matching speakers. I am using some old towers as my surrounds in a 5.1 and like it. But again, I already had them and didnt have to buy anything.--Gary--
When I got my SDA-1C's I moved my RTiA7's to the back for surround duty. Sounds awesome.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Agreed. Staying within the same series is ideal. TSi's all around for me!Chris
5.1
Denon 890
Polk TSi300
Polk TSi100
Polk CS10
MTX SW2 Sub
2.0
Polk SDA-2A
NAD 7175PE -
I have 4 LSi15s after upgrading the rears from LSi7 to LSi15. I will never go back to using small speakers for HT.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I run my SDA-SRS 2.3 TL's in front and LSi-15's for surrounds.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
i've got my standing wife as surround....Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
Towers all around is a great way to go!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Got Power?
7.2 Set Up
Onkyo 805
X-Box
3DO
PS3
Velodyne DPS10 sub
Polk Audio 2- RTI 12's
Polk Audio CSI 5
Polk Audio 4- FXI 5's
Pronto 7500 LCD remote
Gefen HD video 1080p scaler
Mitsubishi TV 73927 1080p
Future purchase Rotel RMB 1095 200x5 THX -
works great. do it.
I'm going to set my sights on a pair of cherry Monitor 70's. Next will be the SW.
Again, thanks for the info. -
I use rtia9's for the front and rti150's which are like the rtia9's but a few versions back. I love towers all the way around. There all set to large also. Except my center set to small. I find with large the explosions and sound effects sound more realistic. My problem is Im one of the few people that can localize bass, no matter where i set a sub I can tell where it is. So I really dont use my little sub in my sig. It was free so I hooked it up.
lol... i wouldnt have my gf if i had towers all the way around.. bookshelf speaker is pressing it .. yikes!!:o -
Would love to find some nice LS90's to run as side surrounds and move my LS50's to the back channels. The room may look like Hell, but it sounds good,lol.
