Towers All Around?
Force
Force Posts: 2
edited January 2010 in Speakers
I recently purchased a pair of Monitor 60 refurbs from the Polk Direct Store on Ebay. They sound great and you couldn't tell that they are refurbs, not a scratch. Got the pair of Cherry for $175.
I'm thinking of using the 60's as my side speakers in a 5.1 and putting Monitor 70's up front with my 55" Sony HD. The room is about 15 X 25 and open ended on one end. I've got plenty of power with my Yammy AV Receiver. Is this overkill? Should I maybe just add some Monitor 40s for the sides?
Thanks.
Mark F.
Post edited by Force on
  • cwilliams
    cwilliams Posts: 58
    edited January 2010
    If you have the speakers already and the room, why not? The 40's would probably serve you just fine if you don't mind stands or using a bracket and wall mounting them. You know you'll have plenty of range with either selection. From everything I've read on here, surrounds aren't as important as the main 3 speakers in the front soundstage.
    Chris
    5.1
    Denon 890
    Polk TSi300
    Polk TSi100
    Polk CS10
    MTX SW2 Sub
    2.0
    Polk SDA-2A
    NAD 7175PE
  • adabro
    adabro Posts: 212
    edited January 2010
    After I upgraded my fronts I moved my 60's to surrounds, they sound good to me...
  • halo71
    halo71 Posts: 4,630
    edited January 2010
    cwilliams wrote: »
    I've heard a few say that as well. But idealy you would want all matching speakers. I am using some old towers as my surrounds in a 5.1 and like it. But again, I already had them and didnt have to buy anything.
    --Gary--
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2010
    When I got my SDA-1C's I moved my RTiA7's to the back for surround duty. Sounds awesome.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • cwilliams
    cwilliams Posts: 58
    edited January 2010
    halo71 wrote: »
    Agreed. Staying within the same series is ideal. TSi's all around for me!
    Chris
    5.1
    Denon 890
    Polk TSi300
    Polk TSi100
    Polk CS10
    MTX SW2 Sub
    2.0
    Polk SDA-2A
    NAD 7175PE
  • BlueFox
    BlueFox Posts: 15,251
    edited January 2010
    I have 4 LSi15s after upgrading the rears from LSi7 to LSi15. I will never go back to using small speakers for HT.
    nooshinjohn Posts: 25,891
    edited January 2010
    I run my SDA-SRS 2.3 TL's in front and LSi-15's for surrounds.
  • devani
    devani Posts: 1,497
    edited January 2010
    i've got my standing wife as surround....
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • danz1906
    danz1906 Posts: 5,144
    edited January 2010
    Towers all around is a great way to go!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • rainman31
    rainman31 Posts: 76
    edited January 2010
    Got Power?
    7.2 Set Up
    Onkyo 805
    X-Box
    3DO
    PS3
    Velodyne DPS10 sub
    Polk Audio 2- RTI 12's
    Polk Audio CSI 5
    Polk Audio 4- FXI 5's
    Pronto 7500 LCD remote
    Gefen HD video 1080p scaler
    Mitsubishi TV 73927 1080p
    Future purchase Rotel RMB 1095 200x5 THX
  • ls7z06
    ls7z06 Posts: 95
    edited January 2010
    works great. do it.
  • Force
    Force Posts: 2
    edited January 2010
    I'm going to set my sights on a pair of cherry Monitor 70's. Next will be the SW.
    Again, thanks for the info.
  • selkec
    selkec Posts: 187
    edited January 2010
    I use rtia9's for the front and rti150's which are like the rtia9's but a few versions back. I love towers all the way around. There all set to large also. Except my center set to small. I find with large the explosions and sound effects sound more realistic. My problem is Im one of the few people that can localize bass, no matter where i set a sub I can tell where it is. So I really dont use my little sub in my sig. It was free so I hooked it up.
  • fluffy
    fluffy Posts: 71
    edited January 2010
    devani wrote: »
    lol... i wouldnt have my gf if i had towers all the way around.. bookshelf speaker is pressing it .. yikes!!:o
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited January 2010
    Would love to find some nice LS90's to run as side surrounds and move my LS50's to the back channels. The room may look like Hell, but it sounds good,lol.
