polk dsw pro 600 popping??
manu4panjab
manu4panjab Posts: 33
edited January 2010 in Speakers
brothers i have polk dsw pro 600 and it pop when i'm listening at -20db or up i usually listening to -30db why is this happening did i play my subwoofer very hard but my old polk psw 125 subwoofer has not any problem at all even when i'm listening to -5db to 0db is my subwoofer damage pleeeeeeeeeeease reply i'm worried :(
polk tsi 500.polk cs 20,polk tsi 200,two hsu uls15 15 inch subs,onkyo 807,ps3(250gb),epson tw3500 1080p projector,optoma 120 inch 16:9 screen
Post edited by manu4panjab on
  • keeneyrm01
    keeneyrm01 Posts: 80
    edited January 2010
    Sounds like it might be defective. I've been told that polk is very easy going about exchanging problems like that for a new or refurbished one. I was told when i bought my sub that polk has a 5 year warranty on the speaker and 3 on the amp for subs.
    HT basement room:
    TV- 42in Panasonic S1 Plasma
    A/V Receiver- Onkyo NR807
    Blu-Ray- 80GB Sony PS3
    Power Supply- Monster HTS-1600
    5 Disc Sony CD/DVD Changer
    Time Warner HD Cable Box
    Speakers:
    Front- Polk RTi A3
    Center- Polk CSi3
    Side Surround- Polk RTi4
    Back Surround- Polk RM6750
    Sub- Outlaw Audio LFM-1 EX
    Bedroom:
    32in Visio LCD, Sony STR-DE685 AVR, MTX Monitor 12, Sony 5 disc DVD changer
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2010
    Email sent.
  • manu4panjab
    edited January 2010
    i will contact my polk dealer here from whom i bought it
  • jacob.simpson
    jacob.simpson Posts: 481
    edited January 2010
    sounds like some serious issue with amp mostly, better unplug
    let the dealer take a look, or if the dealer is close by you can take
    it there and audition it in the showroom..
  • manu4panjab
    edited January 2010
    brothers i just cure the problem actually i was playing sub very hard i set it at -0.5 db and others are around -7db etc ect but when again i set sub volume knob to half and i then run audyssey again and it set my subwoofer now -10db and others at -7db etc etc and no popping sound at all even at reference volume level of avr 0db
  • manu4panjab
    edited January 2010
    dorokusai wrote: »
    Email sent.
    thanks brother for your help i just solve the problem though no need to email polk customer care :D
  • Jdubbs
    Jdubbs Posts: 51
    edited January 2010
    how did you solve it? just curious, I am thinking of getting the same sub. thanks.
    50" Sony LCD
    Denon 3805
    Polk Audio RM 20 system
    Polk Audio 12" sub
    PS3
    Wii
    Harmony One
    HT system #2
    55" Samsung LED
    Pioneer Elite VSX 23
    Fronts, Center- Polk VM 20
    Rears- Polk VM10
    Sub - DSW Pro 600
    Harmony 900
  • manu4panjab
    edited January 2010
    Jdubbs wrote: »
    bro i actually raise sub volume level in avr quiet high like -0.5db that's why but when i ran audysssey test it set my sub to -10db and now my sub don't pop or **** even at super high volumes :D moral is never set subwoofer gain super high :D
  • dorokusai
    edited January 2010
    Jdubbs - He just runs it hard and boosted....I do to, just not THAT high.
  • manu4panjab
    edited January 2010
    dorokusai wrote: »
    yup you are right
