Posted pics of my system...
jaxwired
NAD C545 -> Benchmark DAC1 -> Bryston BP6 -> Bryston 4B SST2 -> Dynaudio Contour S1.4
Post edited by jaxwired on
Cool, nice pics and system. So do tell, how does it sound ?HT SYSTEM-
lsi 9's -
That's some serious wire management going on there....I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
great looking dedicated room! Awesome choice in pictures for the walls also. I have the same CD racks. A true bargain from Ikea!
What subwoofer?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
That is very nice....
I like to see the kids around. Lets me know that there is a future generation that will know about good sound.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Very very nice and very clean. You can come over to my house anytime and clean up the rats nest behind my rack.;)
Oohh - Dynaudio contours....how do they sound?
Very nice clean system and I love the pictures. Are they doubling as room treatments?SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Thanks. Well, it sounds bloody awesome! Clean and crisp with deep articulate bass. I love my current setup. I've been through a bit of gear to arrive at this. Of course, I'm still always planning my next upgrade.great looking dedicated room! Awesome choice in pictures for the walls also. I have the same CD racks. A true bargain from Ikea!
Also thanks. The pics on the side wall are fabric covered acoustic panels from audimute. For an upcharge they let you pick the images (which I did). Yeah, I love the racks from Ikea. Solid metal and only $7 each. I've got 2 more waiting to be installed. The shelf over my equipment rack is also Ikea sourced and looks great.Where is the subwoofer?
Obviously you've never heard Dynaudio Contours before.
They put out some serious bass. But very tight and controlled. More than enough bass for this little 11x14 room. Actually I cannot imaging wanting more bass ever.Oohh - Dynaudio contours....how do they sound?
I'm a big Dynaudio fan. I've tried B&W, Monitor Audio and Spendor before I tried Dyns. Then I went through a few models of Dynaudio before the Contours. The other speaker brands I tried were all very very good and all had great qualities, but not until I got Dynaudio was I satisfied top to bottom. And the Contours are just fanstatic. I really can't even see upgrading to the Confidence line as the Contours are that good. Obviously, it's all a matter of personal preference. Dyn just does it for me...2 Channel
NAD C545 -> Benchmark DAC1 -> Bryston BP6 -> Bryston 4B SST2 -> Dynaudio Contour S1.4 -
Thanks... i'm going to see if i can get ahold of those cd racks.
As others stated and my first thoughts - Very clean.Michael
NORTH of 60° -
Very nice and clean set up. I thought you were one of those Europeans.:rolleyes::DI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Glad to see you are using the Dyn stands for the speakers. Did you mass load them? If not, you should.I really can't even see upgrading to the Confidence line as the Contours are that good.
Thats what I throught at one time.
Arthur SchopenhauerAll truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident. -
Sweet system-Very nice room!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Yes. 3/4 filled with sand (baked in my oven under my wife's disapproving supervision
) 2 Channel
Do you stand and listen lol? I didn't see a chair.
Nice gear m8.Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Pioneer PD-5010 CD player
Sennheiser HD 650s
Maverick Audio Tube Magic D1 DAC
AMD Phenom II 940 @ 3.8 prime stabel
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
Creative X-fI Titanium Fatal1ty -
I have that power conditioner, or one very similar, in my HT. It amazes me that the Sunfire TGA-5400, AVR pre/pro, and Oppo BR only draw 1.7 amps even when it is blasting. I have been thinking of swapping it with my 2 channel power conditioner to see what it draws, but I do not like the fact Panamax does not allow you to turn the lights off on this model.
What does your system draw?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
WOW that must have been a mess. Is it reptile sand? I've used it before and found it to be very dry but a mess nevertheless that's why I use bird shot. -
hearingimpared wrote: »WOW that must have been a mess. Is it reptile sand? I've used it before and found it to be very dry but a mess nevertheless that's why I use bird shot.
Wasn't too big a deal as I already had about half what I needed from my old stands. I used regular playground sound from home depot. But it was not even close to completely dry sand. Had to bake it to get all the moisture out before loading the stands...2 Channel
Sweet system!!!
Nice gear m8.
Thanks. Yes, I have the poang chair from ikea. Very comfortable and perfect for the room.2 Channel
very nice set up.
Clean I love it. I'm a long time owner now past owner of Dynaudio. There stereo reproduction is 2nd to no one. If and when I build a 2 channel system , Dynaudio is on top of my list.
I suggest looking into a Sub 300 to extend your low end. This will give you even more depth and room filling sound. I know all about every single model Dynaudio makes for the last 10 years or so. Adding a sub will absolutely make it better. They are fantastic on there own but don't overlook adding a sub.
Beautiful room man, I like the way you hooked it up. Nice jobDan
Be careful with that type sand as it has the propensity to absorb airborne moisture and become moldy. That's why I asked if you used "reptile" sand as it doesn't hold moisture.
In any case it is a awesome and beautiful system. -
Thanks friend! Great to hear from a fellow Dyn lover. I'll have to keep an open mind about a sub...2 Channel
You should be proud! Georgeous set-up.Remember, when you're running from something, you're running to something...-me
Very sharp. Makes me wish I still lived in Kingsland. I would bum a listen from you.
Excellent system!!! Clean, neat, smooth...and without a doubt sounds awesome to boot.
Nice setup very well done.engtaz
