Nice HTF SVS PB2-ISD Mini-Review
Dr. Spec
http://www.hometheaterforum.com/htforum/showthread.php?s=&threadid=163613
It's nice because this guy has Polk RTi150's all around, Rotel for amps, and also previously owned a PSW450.
SVS
SVS
Post edited by Dr. Spec on
Interesting that he turned it into a front firing sub... Was this suggested because of the 2nd floor set up?At Tom Vodhanel's suggestion, I removed the base plate from mine and have it sat with the ports and controls facing up and the drivers facing forward into the room.
Also he did not state where he set the filter point to blend with the 150's. Four 150's running large with fairly high power driving them plus the 2-ISD, just makes me feel we are not reading the most discerning review here...More later,
Tour...
Vox Copuli
Due to the smaller footprint, some PB2 owners are stacking them on end. I doubt it sounds much different, though. Probably looks a bit weird too, with the cords sticking out the top....
I would assume his PB2 is dedicated to the LFE channel only, both for hi-res audio and for DVD-video.
If that is the case, then he sets the filter switch to Disable and it plays whatever the processor sends it.
It wouldn't even play for 2 channel music in that case.........worth a question, methinks."What we do in life echoes in eternity"
SVS -
Makes sense... thanks and good morning...More later,
Tour...
Vox Copuli
Good morning to you........it's archery opener in my parts. Have bow, will travel. You've been tearing up the forum lately - nice work."What we do in life echoes in eternity"
SVS
