Need help! rti issues
rcrook317
i came home yesterday and discovered my left tower(rti12) is not making any sound.....but the bottom three drivers are vibrating as if theyre getting bass notes but not sound out of any of the speakers or tweeter in left tower.My towers are ran thru a kenwood amp(2ch) then thru my hk 354 via rca interconnects,the amp meters showed full power going to both spearkers.
this is what ive done so far
1.reconnected ALL connections,insuring they are solid/snug.
2.rechecked all avr settings to make sure all were set to play thru front towers.
3.bypassed amp and hooked straight to reciever to disqualify the amp as problem source.
I have no idea what has happened but i believe something inside has come loose(wire connection) somewhere or there is a problem w the internal crossover maybe?Im guessing this because the left tower is the one i scoot back and forth to get behing the tv to do any cable mgmnt.I know what blown speakers sound like and this is not it,theres no distortion at all .
So....any ideas,solutions?
any idea were an authorized repair place is around central indpls?
fronts=rti12s(cherry)
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
audioquest diamondback 1m
"Maesto" straightwire cables
pangea ac-9
playstation3/120gb=blu-ray/media server
monitor=lg 55inch lcd(1080p)
TT Set-up=Pro-Ject RM 1.3
Kenwood Phono
bren1 Clamp
Herbies Slipmat
"It doesnt mean that much to me,to mean that much to you"
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
pangea ac-9
Kenwood Phono
bren1 Clamp
Herbies Slipmat
Post edited by rcrook317 on
have you switched positions of the speakers?
sounds like a crossover issue or a loose wire internally.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
exactly what i was thinking.....
should i switch the wires to right front on reciever and try that?will it make difference?
how much money we talking?ballpark?
Im freaking out here!fronts=rti12s(cherry)
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
pangea ac-9
Kenwood Phono
bren1 Clamp
Herbies Slipmat
"It doesnt mean that much to me,to mean that much to you" -
just move the speaker to the side that is known to work and try it there. If it fails, then something inside has gone haywire. A call to Polk CS will help you figure it out from there.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
will do shortly(lil one asleep)
doesnt polk cs check this section?hoping they do...
Curious how much this gonna set me back,im definitely not shipping this bad boy anywhere,hope polk can suggest place for repairfronts=rti12s(cherry)
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
pangea ac-9
Kenwood Phono
bren1 Clamp
Herbies Slipmat
I am not certain that will be needed. If they determine a crossover is in order, they may just send you one. In the meantime, pull a couple drivers and check the wiring to the crossover.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
dumb question time....
where is crossover located? how would i get to it?
when i first hooked these up i blew a tweeter and called polk and replaced it myself but i have no idea about the crossover.im gonna check all connections to the speakers here shortly to insure they are good but can anyone explain the crossover to me?
thanks.fronts=rti12s(cherry)
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
pangea ac-9
Kenwood Phono
bren1 Clamp
Herbies Slipmat
the crossover is inside the speaker, most likely on the terminal cup, if you remove the lowest driver from the cabinet you can shine a flashlight inside and find it easily. The troubles may just be a loose connection at the crossover. Is there a line fuse for the speakers? My amp has main fuses and two for each channel.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
have no idea about the fuses in the amp,matter of fact the amp is on loan,pending if i decide to buy it or not.thanks for tip on crossover,now just gotta find my allen wrench set and give it a go,hope its something simple as a loose connection or il be calling polk for suggestions?!?fronts=rti12s(cherry)
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
pangea ac-9
Kenwood Phono
bren1 Clamp
Herbies Slipmat
Polk CS without hesitation sent me 1 tweet , 2 mids for my A9's. Woke up tweet was tinny and high pitched and mids were dead. Wonderful people!
that should be a torx bit not an allen. a t-12 or 14 I think. if it is your xo its not as hard of a fix as you might think and with your club discount it should cost you about 45 bucks. with some tips from the fellas here and polk cs it took my rookie **** about an hour and a half to do, and I found doing it myself to be very rewarding in many ways. here's the thread when I did mine
http://www.polkaudio.com/forums/showthread.php?t=93536panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
thanx super.....i just glanced at it,thought was allen wrench......guess il head to hardware store.been at work havent had time to take it apart yet.....fronts=rti12s(cherry)
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
pangea ac-9
Kenwood Phono
bren1 Clamp
Herbies Slipmat
no problempanasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one
