Need help! rti issues
rcrook317
rcrook317 Posts: 280
edited January 2010 in Troubleshooting
i came home yesterday and discovered my left tower(rti12) is not making any sound.....but the bottom three drivers are vibrating as if theyre getting bass notes but not sound out of any of the speakers or tweeter in left tower.My towers are ran thru a kenwood amp(2ch) then thru my hk 354 via rca interconnects,the amp meters showed full power going to both spearkers.
this is what ive done so far
1.reconnected ALL connections,insuring they are solid/snug.
2.rechecked all avr settings to make sure all were set to play thru front towers.
3.bypassed amp and hooked straight to reciever to disqualify the amp as problem source.
I have no idea what has happened but i believe something inside has come loose(wire connection) somewhere or there is a problem w the internal crossover maybe?Im guessing this because the left tower is the one i scoot back and forth to get behing the tv to do any cable mgmnt.I know what blown speakers sound like and this is not it,theres no distortion at all .
So....any ideas,solutions?
any idea were an authorized repair place is around central indpls?
fronts=rti12s(cherry)
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
audioquest diamondback 1m
"Maesto" straightwire cables
pangea ac-9
playstation3/120gb=blu-ray/media server
monitor=lg 55inch lcd(1080p)
TT Set-up=Pro-Ject RM 1.3
Kenwood Phono
bren1 Clamp
Herbies Slipmat
"It doesnt mean that much to me,to mean that much to you"
Post edited by rcrook317 on
    nooshinjohn Posts: 26,000
    edited January 2010
    have you switched positions of the speakers?
    sounds like a crossover issue or a loose wire internally.
  • rcrook317
    edited January 2010
    exactly what i was thinking.....
    should i switch the wires to right front on reciever and try that?will it make difference?
    how much money we talking?ballpark?
    Im freaking out here!
    center=csi3(cherry)
    sub=psw125(cherry)
    emotiva xpa-2
    harmon kardon 354
    sony cdp
    ipod 8gb
    pangea ac-9
    Kenwood Phono
    bren1 Clamp
    Herbies Slipmat
    edited January 2010
    just move the speaker to the side that is known to work and try it there. If it fails, then something inside has gone haywire. A call to Polk CS will help you figure it out from there.
  • rcrook317
    edited January 2010
    will do shortly(lil one asleep)
    doesnt polk cs check this section?hoping they do...
    Curious how much this gonna set me back,im definitely not shipping this bad boy anywhere,hope polk can suggest place for repair
    center=csi3(cherry)
    sub=psw125(cherry)
    emotiva xpa-2
    harmon kardon 354
    sony cdp
    ipod 8gb
    pangea ac-9
    Kenwood Phono
    bren1 Clamp
    Herbies Slipmat
    edited January 2010
    I am not certain that will be needed. If they determine a crossover is in order, they may just send you one. In the meantime, pull a couple drivers and check the wiring to the crossover.
  • rcrook317
    edited January 2010
    dumb question time....
    where is crossover located? how would i get to it?
    when i first hooked these up i blew a tweeter and called polk and replaced it myself but i have no idea about the crossover.im gonna check all connections to the speakers here shortly to insure they are good but can anyone explain the crossover to me?
    thanks.
    center=csi3(cherry)
    sub=psw125(cherry)
    emotiva xpa-2
    harmon kardon 354
    sony cdp
    ipod 8gb
    pangea ac-9
    Kenwood Phono
    bren1 Clamp
    Herbies Slipmat
    edited January 2010
    the crossover is inside the speaker, most likely on the terminal cup, if you remove the lowest driver from the cabinet you can shine a flashlight inside and find it easily. The troubles may just be a loose connection at the crossover. Is there a line fuse for the speakers? My amp has main fuses and two for each channel.
  • rcrook317
    edited January 2010
    have no idea about the fuses in the amp,matter of fact the amp is on loan,pending if i decide to buy it or not.thanks for tip on crossover,now just gotta find my allen wrench set and give it a go,hope its something simple as a loose connection or il be calling polk for suggestions?!?
    center=csi3(cherry)
    sub=psw125(cherry)
    emotiva xpa-2
    harmon kardon 354
    sony cdp
    ipod 8gb
    pangea ac-9
    Kenwood Phono
    bren1 Clamp
    Herbies Slipmat
  • Krazyz1
    Krazyz1 Posts: 256
    edited January 2010
    Polk CS without hesitation sent me 1 tweet , 2 mids for my A9's. Woke up tweet was tinny and high pitched and mids were dead. Wonderful people!
  • superjunior
    superjunior Posts: 1,632
    edited January 2010
    rcrook317 wrote: »
    that should be a torx bit not an allen. a t-12 or 14 I think. if it is your xo its not as hard of a fix as you might think and with your club discount it should cost you about 45 bucks. with some tips from the fellas here and polk cs it took my rookie **** about an hour and a half to do, and I found doing it myself to be very rewarding in many ways. here's the thread when I did mine
    http://www.polkaudio.com/forums/showthread.php?t=93536
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • rcrook317
    edited January 2010
    thanx super.....i just glanced at it,thought was allen wrench......guess il head to hardware store.been at work havent had time to take it apart yet.....
    center=csi3(cherry)
    sub=psw125(cherry)
    emotiva xpa-2
    harmon kardon 354
    sony cdp
    ipod 8gb
    pangea ac-9
    Kenwood Phono
    bren1 Clamp
    Herbies Slipmat
  • superjunior
    edited January 2010
    rcrook317 wrote: »
    no problem
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
