Need info on subs
32deuce
I am needing to find out what type amp is powering these subs.
PSW 202
PSW 250
PSW 303
I've had issues with class D amps and interference, so im hoping any of these 3 are using a class A/B amp to power it. Deuce
PSW 202
PSW 250
PSW 303
Post edited by 32deuce on
Bump..need info asap..Thanks
I don't really know if anyone has that info unless they own these and have opened them up. My suggestion is call up Polk Customer Service and see if they have someone there who knows!
Are ya hearing CB radio or cell phone conversations through your subs?
--Gary--
Affecting radio reception. I had a Velodyne, didnt matter where i put it, it put out interference. I called Velodyne, found out sub was a class D. Back to the store it went.
Tried an Energy sub, same issue. Contacted C.S., they said sub was a class D. Back went that sub.
Tried a friends Polk psw 110, no interference! Also, the Polk uses a class A/B amp.
I thought Polk C.S. monitored this link. I guess ill have to give them a call.
Deuce -
They do monitor this part of the forum, but you're asking about subs that aren't sold anymore I don't think. That's weird that you got the same problem with all those different subs
Do you live really close to a tower? I'm not sure, but isn't that usually indicative of some sort of poor ground issue? Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
rallyshark wrote: »They do monitor this part of the forum, but you're asking about subs that aren't sold anymore I don't think. That's weird that you got the same problem with all those different subs
Problem was with the 2 subs that used class D amps. The Polk of my friend, did not cause interference, and it used a class A/B amp.
I had read on the net about this issue. I'm one of the unlucky ones to have this problem.
Also, no tower near me.
Deuce -
I've had a couple class D subs with no such problems. But who knows...give the boys a call?
