Need info on subs
32deuce
32deuce Posts: 49
edited January 2010 in Troubleshooting
I am needing to find out what type amp is powering these subs.
PSW 202
PSW 250
PSW 303
I've had issues with class D amps and interference, so im hoping any of these 3 are using a class A/B amp to power it. Deuce
Post edited by 32deuce on
  • 32deuce
    32deuce Posts: 49
    edited January 2010
    Bump..need info asap..Thanks
    edited January 2010
    I don't really know if anyone has that info unless they own these and have opened them up. My suggestion is call up Polk Customer Service and see if they have someone there who knows!
    cnh
  • halo71
    halo71 Posts: 4,607
    edited January 2010
    32deuce wrote: »
    Are ya hearing CB radio or cell phone conversations through your subs? :p
    --Gary--
  • 32deuce
    32deuce Posts: 49
    edited January 2010
    halo71 wrote: »
    Affecting radio reception. I had a Velodyne, didnt matter where i put it, it put out interference. I called Velodyne, found out sub was a class D. Back to the store it went.
    Tried an Energy sub, same issue. Contacted C.S., they said sub was a class D. Back went that sub.
    Tried a friends Polk psw 110, no interference! Also, the Polk uses a class A/B amp.
    I thought Polk C.S. monitored this link. I guess ill have to give them a call.
    Deuce
  • rallyshark
    rallyshark Posts: 417
    edited January 2010
    They do monitor this part of the forum, but you're asking about subs that aren't sold anymore I don't think. That's weird that you got the same problem with all those different subs:confused: Do you live really close to a tower? I'm not sure, but isn't that usually indicative of some sort of poor ground issue?
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
  • 32deuce
    32deuce Posts: 49
    edited January 2010
    rallyshark wrote: »
    Problem was with the 2 subs that used class D amps. The Polk of my friend, did not cause interference, and it used a class A/B amp.
    I had read on the net about this issue. I'm one of the unlucky ones to have this problem.
    Also, no tower near me.
    Deuce
    edited January 2010
    I've had a couple class D subs with no such problems. But who knows...give the boys a call?
    cnh
