The M&K Takes a step up to the plate
VR3
Well, i recently was just fed up with all this terrible bass that never was there and never could keep up. Now I'm turning it down!
How is this so? It is not my mind, the SPL meter does not lie! It is running 4-5db louder! it sounds cleaner, fuller, dosn't bottum out as much or anything! I also have bass at all volumes!
The secret?
Speaker wire! Lots of it! Does your preamp have a crappy sub out? Use speaker wire! The difference.....HUGE! The M&K hits 110db continuously, staying blended. This is 4 db above its usual rating with a LFE cable. This is at the same regular volume, just this time with speaker wire. Works well. If you have no tried this, I would definetely try it!
The secret?
Post edited by VR3 on
And all that with a blown driver....
Nothing to see here, move along...Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Yep! I'll take a picture of the SPL meter!
It's in a 10.5x10.5 room.....- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Read it! Weap it!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
PS: When I say 'regular' volume, I mean 102db with the speakers
The level of your fist hitting your sack repeatedly?
M&K, 2 drivers, one is blown - thanks for playing.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Lets see....tiny room, sub in one corner, meter in opposite...Even my cheapy MTX SW1 can sound loud as **** like that.
If he's using music that never touches 40 hz and hes hitting a room induced peak, it's possible.
edit
{also remember that you can run it at ungodly high THD and still call it a "reading"}
edit 2
{I think rat shack meters have a 2dB or so accuracy, so it could be a high 113, too} -
Well when I took that reading, I was playing Korn - Children of the Korn. Anyone that is familiar with that song will tell you the entire song is bass heavy. With the LFE cable my max reading was 111db. With the speaker wire, as you can see was 115- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
its a high powered input versus a coax unput, i think that explains it..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Don't believe that the sub can draw from the mains' amp's output. However, running two speaker wires vs. one cable willl yield a 3 dB input boost... about what Sid is seeing.
Now as to why the M&K is not bottoming out??? I dunno, that should be a function of output... Unless Sid is still running his mains "small" and the sub is not only seeing upper bass frequencies instead of the deep bass the cable was feeding it...More later,
Tour...
Vox Copuli
Well you can't hear the M&K bottum when it does, it's a brisk noise that is only heard when the mains are off. So if it is there it's low enough that the mains drown it out.
I am running the mains on large, sub off. Speaker wire everywhere. Subwoofer still plugged in, running off of it's own amp and volume control. Crossover set at 65hz (vs the old 120hz xover because of the 100hz internal receiver crossover, this is one reason why the subwoofer runs much easier now). I am greatly satisfied with the results I found, and will probally continue to wire about every subwoofer I do like this.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
115db?
Well, don't worry, listening to stuff that loud, you won't be listening for long.
'The level of your fist hitting your sack repeatedly?'..
GOLD, Jerry, GOLD!
K. BaniaI plan for the future. - F1Nut -
That explains it... you unburdoned the M&K of the upper bass and are getting double duty in the 40 (or so) to 65 Hz range with the "stacks" on large... Well done.Originally posted by Vr3MxStyler2k3
But do take the hearing cautions you are getting seriously. Even a steady diet of 100 dB sessions are going to slowly take their toll...More later,
Tour...
Vox Copuli
I did that to see how loud I can go. I usually dont listen above 96-98 db. *In Bass* and 92-93 in the mid-high level- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
"To see how loud it would go"
And how did you know when to stop, when it started to smell like crack? -
Where it didn't surpass its limits...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
and your mom and dad or ok with KORN playing this loud? They never tell you to "turn that noise off"? you have pretty understanding parents i'd say.PolkFest 2012, who's going>?
My Mom likes Korn, my Dad does not live here.....- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
