get a bigger amp or get a sub ?
I have a pair of polk rtia9's powerd by a rotel rb-1080. I want more bass.Should I upgrade my amp to a rb-1092 or get a subwoofer ?? I only listen to music.
Post edited by Neale13 on
sub vote hereSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
If you listen to more movies I would get the sub. If you listen to more music like me get the amp:D How do those A9's sound? I have the Rti12's which are the older towers. A good amp would definately make those A9's come alive!HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
Music+ Amp.........Movies+SubLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
The a 9s sound great.i blew the 1080's fuses once and rotel said the speakers were under powerd ?? Im not so sure what the issue is ive heard differnt reasons.So the bigger amp will make a noticeable change ? -
Another vote for amp.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
They did for me on my my Rti12's which are similar to yours. Your's are better and if you have those great speakers they are begging to be driven properly. I have a Carver TFM35x driving my Rti's and the Carver will continue to drive them unless I get a bigger Carver:DHT System
So do you think I should get the rotel rb-1092 ?
Well,the 1080 is a decent amp and I believe it is around 200w/ch.That should handle those A9's okay and you said in your op that you just want more bass so if that is all you want then get the sub.The 1092 I believe is more than twice as powerful and it would be interesting how much better it would make your A9's sound. Like I said earlier, if you listen to music my first concern with good speakers would be the amp. If you do get a sub,get one that is tight and fast for music.This would depend on your budget.HT System
A Sub will get you much more bass per dollar then an amp will, on that note make sure it is NOT the psw10, aka get a good sub.Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Pioneer PD-5010 CD player
Sennheiser HD 650s
Maverick Audio Tube Magic D1 DAC
AMD Phenom II 940 @ 3.8 prime stabel
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
Creative X-fI Titanium Fatal1ty -
Depends how low of bass are you looking for. Rap bass which is really low will need a sub. However, if you were to get a nice amp like say a Carver tfm 45 those rti12 would be loud as %$^&* in the 40-50-60hz department. DONT underestimate those little 7 inch drivers. They will pound with enough powerHOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around -
lol,
+1,
Get yourself a nice SVS and you'll have BIG BASS!!
I also agree that for music you might just want a better 2 channel amp..
But the sub would be easiier and cheaper.
You absolutely do not need a better amp. The Rotel RB1080 is more then enough power for your speakers and then some.
Get yourself a good sub.Dan
Another sub vote. You said you want bass and subs make bass.Mains - LSi9's
Center - LSiC
Surround - pair of TL3's
Amplification - Parasound 2125
AVR - Onkyo 706
CD/SACD - Onkyo DV-SP506
SUB - MartinLogan Abyss
55" Panasonic Viera TC-P55GT30 3D
Bluray - DMP-BDT310 Panasonic -
If you blew the fuses on the 1080, I'd say try a amp from a different manufacturer
When the a9's get enough juice they produce quite a bit of bass, a sub is probably the easier route though....Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
I agree it would be an easier route although an Emotiva XPA-2 would probably wake these puppies up for the price of a decent sub .sTiLlLeArNiNg wrote: »When the a9's get enough juice they produce quite a bit of bass, a sub is probably the easier route though.... -
Tell us about your pre-amp... are you sure that you don't have any kind of crossover engaged?Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Buy a bigger amp and send me the RB-1080. I've been wanting one forever
Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Good point ! -
rotel rc-1070 -
The 1080 seems not to be enough power .When I turn the volume past 35 % the sound starts to not sound so great any more.(starts to distort) I think I want the bigger amp.rb-1092. George from rotel told me I was underpowering my 500w rtia9's. Im pushing them with a newer rb-1080. The fuses blew once on one channel.He said it would keep happening unless i kept the volume low.
