USB Sound Card
Everything will play through it. He only wanted to disable the windows default dings etc.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
To the OP,
What do you currently have for sound on your computer? Anything with an optical output? If so, you could probably find a decent stand alone DAC that would sound better. -
I have a crappy onboard sound solution, it's terrible, which is why I'm looking at other options.
AsSiMiLaTeD wrote: »So if I install one of these will it only serve as the sound device for Winamp? What about other Windows sounds, stuff like YouTube videos and all that?
Any audio will play through whichever device you set to the default in the Windows control panel.
A cool thing about audio player programs like Foobar (which I highly recommend) and Winamp is that you can set the output device to be your USB DAC for music listening, but keep the Windows control panel default set to the computer's sound card/speakers for normal computer activities.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
Gotcha
I've worked with computers for years, and I guess the thought of simply getting sound via USB without alot of work just sounds to good to be true, but apparently it's fairly common.
I'm looking at the models on hotaudio and am reading that they are just plug and play, and people online seem to like them alot. I wasn't looking for great sound, but looks like I may be able to actually get decent sound quality and not have to spend a ton. -
Here's another sub $100 unit that gets good feedback.
http://www.audioadvisor.com/prodinfo.asp?number=HRTMS5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
Maybe its just me, but for ~$100, I'd rather have a full blown high quality USB sound card complete with inputs, headphone output, and ASIO drivers. I'm referring to the E-Mu 0202 USB. You'll probably find just as many folks over at Headfi who love the 0202.
It can probably be said that the driver complement is more complicated with the E-Mu unit. I won't deny that. It will have normal sound card drivers that must be installed, and it also needs something called E-mu Patchmix DSP to run. Patchmix is like a mixing board, you can tell the device exactly how to route the inputs/outputs. I don't find the E-mu drivers or software to be the slightest bit unstable. I've been using the E-Mu 0404 for a little more than 18 months and I still love it. Great sounding output, very stable drivers, AND, it records great (I've done some really nice vinyl rips). -
I picked up a couple of these when Comp USA when under.
http://us.store.creative.com/Creative-Xmod/M/B000IZ96LQ.htm
It actually sounds pretty good, far better than the crappy sound card in my laptop or my desktop at work. At home I use it when we sit in bed and watch movies on the laptop. At work I use one for music played through a set of Boston Acoustic speakers.
StanStan
Main 2ch:
HT:
Other stuff:
How's the headphone section in the 0202?
One thing that's appealing about the hotaudio models I'm looking at is that they also double as a decent headphone amp, how does the e-mu fair in that area? -
AsSiMiLaTeD wrote: »How's the headphone section in the 0202?
You'll have to search around at Head-fi. I don't have that model. I'm sure it depends greatly on which set of cans you have. I wouldn't expect it to push a set of inefficient Senns, but maybe a set of Grados. -
I rip my music to a second hard drive, then got an internal sound card. My problem was whenever my PC read from the hard drive, the sound card got noisy. I only need a USB connection with my PC and two channel out, so after some research, I got a SilverStone EB01 and have been happy. http://www.sundialmicro.com/silverstone_sound_controller_ssteb01b_2111_624.html
HP desktop / Window7 64 bit / J. River Media JukeBox / WMA Lossless
SilverStone EB01 USB DAC
ONKYO A-9555
Canare Star Quad 4s11 Speaker Cable - Biwired
Polk RTi8 -
MLZ, the Silverstone was another $100 unit that I was going to recommend, but could not find it at Newegg.com, so figured they were history.
I checked out your link for kicks and learned that they want $30 for ground shipping to Ohio - something wrong with that.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
I was in Fry's today and saw the e-mu 0202 for 115. I decided to go ahead and pick one of those up.
I also ordered the least expensive dac from hotaudio.
I'm gonna hook up that e-mu later tonight and will post my thoughts on that later. -
So....
Apparently there are no Windows 7 drivers for the e-mu device. I should have done this research up front, so that's on me I suppose.
I tried installing the current (dated 02/2008!!!) driver and it's a no go in Vista. -
Stupid edit time limit...
I meant to say it's a no go in Windows 7. The drivers claim to have Vista support, but it's not working in Windows 7 for me. -
Does it have to be USB? If not check out Asus Xonar cards.Shoot the jumper.....................BALLIN.............!!!!!
Thats what I m saying Asus for pure sound and Creative X-fi for gaming or HT.
Asus is another brand that i'm very familiar with.
Also HT omega is worth a look for real sound cards that can actually process data vs Just a DAC. Merit for both but if you looking for a digital source internal cards are the way to go.Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Pioneer PD-5010 CD player
Sennheiser HD 650s
Maverick Audio Tube Magic D1 DAC
AMD Phenom II 940 @ 3.8 prime stabel
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
Creative X-fI Titanium Fatal1ty -
ONKYO A-9555
Polk RTi8
Thats a weird problem LOL. by the way there is almost never a time when your PC is not reading from your hard drive. It is in fact reading from your hard drive almost constantly.
That sounds like a driver problem or Mobo problem rather then a sound card problem.Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Sennheiser HD 650s
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
AsSiMiLaTeD wrote: »So....
your saying the vista drivers don't work in win 7? or you duel booted and it dose not work in vista as well?Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Sennheiser HD 650s
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
AsSiMiLaTeD wrote: »Stupid edit time limit...
http://www.amazon.com/M-AUDIO-Transit-Resolution-Mobile-Upgrade/dp/B0000CDHP5/ref=sr_1_1?ie=UTF8&s=musical-instruments&qid=1263692682&sr=8-1 -
I took the e-mu back and picked up a m-audio model. It's somewhat similar, with a little less functionality but is supposedly compatible with windows 7. I'll be testing later tonight.
The m-audio does only do 24 bit 44 khz vs 96 khz on the emu, can someone explain to me what I'm losing there?
I need the USB capability because I also want to be able to use it with a laptop. -
I had no problems using the E-mu 0404 (PCI) Vista drivers in Windows 7 64bit. Worked 100% for me. What exactly is the problem? Silly question, but are you installing them as Admin?
A quick search at Head-Fi and other people are using the Emu USB units with Windows 7 and they seem to be ok, few minor issues, but working anyway. -
AsSiMiLaTeD wrote: »The m-audio does only do 24 bit 44 khz vs 96 khz on the emu, can someone explain to me what I'm losing there?
The Transit model I sent a link to does 96kHz. I have two of those for work and they work great. -
When I plugged the emu in any application that would try to use audio (winamp, media player, even the audio properties in control panel) would lock up, I could unplug the device and it's fine, but as soon as I plug the device in whatever app just locks up.
Maybe I got a lemon, who knows. The one thing I will say is that the latest drivers I could find are dated February, of 2008! I'm not going to hand my money to a company who doesn't prove up to date driver support for their products.
Sami, I'll kook into that transit device as well -
AsSiMiLaTeD wrote: »I took the e-mu back and picked up a m-audio model. It's somewhat similar, with a little less functionality but is supposedly compatible with windows 7. I'll be testing later tonight.
The only time you would be losing musical information is if you pay high ress lossless files and then you would not be losing vitally important amounts of information unless you have a high end audio set up you wouldn't notice.
(that spec is called the sample rate higher the better)
Other wise its pretty much comes down to which one gets better reviews cheaper or looks prettier. which ever combination of those factors matters more to you should determine which one you buy over a higher sample rate spec.Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Sennheiser HD 650s
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
AsSiMiLaTeD wrote: »When I plugged the emu in any application that would try to use audio (winamp, media player, even the audio properties in control panel) would lock up, I could unplug the device and it's fine, but as soon as I plug the device in whatever app just locks up.
Sounds like setup issues, not incompatible drivers. -
^^^ Care to elaborate on that? A faulty driver would explain exactly what I'm seeing, and could be the cause of 'setup issues'. Like I said it could have just been a lomen unit, I did pick it up at the local Frys and it was a previously returned product. I typically don't buy those, but Frys had 6 of these on the shelf and they were all previous returns, so I had no option.
Keep in mind I'm not an idiot when it comes to computer stuff, so this isn't a case of me 'not being able to figure it out'.
At any rate, I got the M-Audio set up last night and its working great. The audio is TONS better than the crappy on board sound with both my desktop and laptop, well worth the $100 I paid for it.
I will say though that the E-Mu is a more well-featured product than the M-Audio, it has a 1/8 stereo mini output jack vs just the rca on the m-audio and a bigger 1/4 headphone jack vs the 1/8 on the m-audio. It also has 96 hz vs 44hz, but from what I'm reading and what I'm using this setup for that shouldn't matter to me.
Bottom line, I 'think' the E-Mu 0202 is actually the better piece of hardware given it's features and specs. The nice thing about the M-Audio is that it works, and is perfect for what I need. I sent an email to the E-Mu support team last night asking about Windows 7 support, citing the problem I had and the more 'minor' issues that I see being discussed everywhere else.
As soon as Creative gets off their **** and give me a set of drivers that are not 2 freaking years old I'll actually pick one of those up and use the M-Audio strictly for the laptop. It's not like these devices are discontinued, I could at least understand not supporting discontinued devices, but to have a computer related device that you're still selling that hasn't had a driver update in 2 years is simply unacceptable - show me another example of that and I'll reconsider my position.
Bill, I do appreciate the tip on the E-Mu, because now I at least know to to keep an eye on that device. It didn't work out for me right now, but I don't want to sound ungrateful for the help, which is probably how I'm coming across. -
Not implying your a computer schmuck, but pro sound cards and ASIO drivers can be confusing if you have never used them. Things like DCP latency, matching the sample rate between windows and EMU drivers, etc.
For whatever reason, those 2 year old Emu drivers work perfect for me and my 0404PCI under Windows 7 64bit.
The reason they are 2 years old is that is when Vista came out. They were perfectly stable under Vista, so there has been no need to update them. They are still working on Windows 7 drivers, as are many hardware companies.
Glad to hear you are happy with the M-audio.
Back when I bought my Emu, I was looking at some of the M-audio products, but they didn't have any compatible drivers for my 64bit (XP) system. I guess they have caught up. -
It was only with the 2nd added HD most noticible if my amp was on and I also was copying data to my new drive. Anyway, the EB01 solved all that.:) -
Okay, so I have an update and some more questions:
I decided to take the M-Audio back and give the E-Mu another try. The M-Audio worked fine, but the idea of the extra features on the E-Mu kept nagging at me and like i said before, I know it's got to be a better device.
For the first hour I started out with the exact same results as last time. Don't ask me how, but on the second attempt this time around I got it working. I didn't do anything different, it just worked this time.
So at this point I have a (mostly) working device. The problem that I'm having now is pops and crackles in the music. I'm reading in the manual and it talks about ASIO buffer size, but I'm not sure how to adjust it.
For the moment, let's say that I only care about playback and not recording, what do I need to do to get this thingight? I'll worry about recording at a later time when I get ready for that.
